Question about Lexmark X1150 All-In-One InkJet Printer
Replacement part. The receptacle that holds the black ink cartridge in place has broken. It will no longer snap down to hold the cartridge in place. I need a replacement part. Is this available?
  • Anonymous Mar 20, 2014
    The Cartridge Door is broken and can not close to hold the cartridge in place.
    The black ink cartridge door is broken and do not snap down to hold the cartridge in place.
  • 23 Answers
There is no replacement part. U can call lexmark tech support & chkd the warranty of the printer. if its in warranty they will replace it other wise they will give u a 20% discount coupon to buy another lexmark printer. Call 800 332 4120
Posted on Jun 20, 2008
The top piece that holds the black print cartridge in place when releasing the tab is broken
Dell does not offer a replacement for that broken piece.
So, your only choice is to replace the printer,
hopefully, with one that takes identical ink-cartridges.
Jan 15, 2011 | Dell 948 All-In-One InkJet Printer
How do you replace the ink cartride in a hp 2175 all in one printer
1. Prepare the replacement cartridge by pressing down and back on the top of the protective plastic, then sliding the cartridge out.
2. Set both the cartridge and empty cartridge protector aside.
3. Turn on your printer and lift the access door until it locks into place. The print carriage will move to the center.
4. Once the print carriage has stopped moving, raise the latch to release the empty cartridge. 5. Remove the empty cartridge by pulling towards you. If you are replacing the tri-color cartridge and need to remove the black ink cartridge temporarily, use the empty cartridge protector to hold it. 6. Hold the replacement cartridge by the sides and remove the black plastic tape. 7. Insert the replacement cartridge into the appropriate slot (left for tri-color, right for black) until it snaps into place. 8. Pull the cartridge latch towards you and press down until it snaps into place. 9. Close the access door. -------
You may also download and refer to it's product manual :-
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
and
http://h10032.www1.hp.com/ctg/Manual/bpu73554.pdf
Sep 25, 2010 | HP PSC 2175 All-In-One InkJet Printer
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
X-spring tab broken in ink receptacle (HP officejet 7310)
I think you right. There are a lot of small parts which are finely tuned in a printer and most likely something else is still affected.
You probably are better off purchasing a new unit, unless you have the time and patient to figure it out.
Good Luck!
Sep 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The lever that holds ink cartride in place is broken
take out the old cart'd, and get yourself some "loctite" power grab "red tape at walmart, insert the new cart'd and use the "loctite" at the top, allow it some time to "set up", and you should print a "test page", and you should be good to go, god bless
May 29, 2009 | HP PhotoSmart 7760 InkJet Printer
Cartridge Error 50 C in manual A 960 No l
One solution is to replace cartridge snap-down levers  (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). This seemed to have work for several people with the same issue.
Nov 25, 2008 | Dell A960 All-In-One InkJet Printer
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
How to insert ink
you mean ink cartridges?
Remove the tape from cartridge.
Caution: Do not touch the copper-colored contacts of the cartridges. then hold on the top HP logo. Insert it (tri-color cartridge- left slot)-(Black cartridge- right slot) make sure you push the cartridges firmly until they snap into place.
see your manuals dear, you have it with your printer u bought.
Aug 02, 2008 | HP Office Equipment & Supplies
Error C50 on Lexmark X6170 printer
The ultimate permanent fix for the x6170 printer would be to purchase new cartridge snap-down levers (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). If you purchase snap down levers for a Lexmark printer series X5100 or X6100 or Z55 or Z65, the little guide peg inside the snap lever would work with an unmodified 83 and 82 Lexmark cartridge. All Lexmark did for Dell to make the Dell unique, was to put special Dell snap levers on the printer. I considered breaking off the little guide peg on the snap lever, but decided against it as it appears to help hold the cartridge in alignment
Mar 08, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
95 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
