Question about Maytag Dryers
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling freely. Like something fell off and is tumbling inside. How do I open the unit and should I be worried about a fire starting? Do you have any thoughts as to what this noise could be?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 13, 2010
My Maytag Performa electric dryer heats and tumbles, but the clothes take multiple cycles to dry, and water is pooling next to the left front foot. We cleaned the vent, replaced the vent hose, and opened...
two things come to mind; 1. although drum is rotating perhaps it is slipping under load. Change drum belt, and, 2. perhaps the problem isn't in the dryer, it could be that your washer is not spinning out properly leaving an inordinate amount of water in your clothes which would tax the performance of the dryer. Just a thought. good luck!
Aug 19, 2013 | Dryers
My Maytag Performa dryer is making a horrible sound...still working though. Wondering if it is a belt?? Can I fix myself?
go to Sears and purchase the belt with an idler pulley with it. It comes as a kit. The pulleys bearing has dried out bearing that went flat in spots which causes this horrible noise
the top and the front of your dryer needs to come off to access these parts
Jan 13, 2011 | Maytag Dryers
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Noisy maytag dryer
the blower wheel sounds like it is bad it should be tight on the shaft and not turn unless the tub turns
Nov 15, 2008 | Maytag PYE2300AY Electric Dryer
Clothes dryer makes alot of noise when spinning....what can cause this...still dries clothes fine
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Jul 11, 2008 | Maytag Performa PAV2200
Dryer noise
open the door and if u can lift the drum up or down more than an inch the drum bearings are worn out. big job to repair unless under warranty.
Feb 07, 2008 | Dryers
Dryers Logo
377 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
