Question about GE Spacemaker JVM1640SJ Microwave Oven
How do i remove a out door frame of a GE profile spacemaker 1800?
  • 5,911 Answers
If you are referring to the disassembly and replacement of the door, just follow these steps:
1. On MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
2. With the inner panel removed, locate the door handle screws and remove with a screwdriver.
3. The panel glass should be "sandwiched" in place (double layer on most ovens) and should either lift out, or have retaining clips holding in place. Remove and set aside.
4. The remaining piece(s) comprise the door frame. Replace as necessary.
REASSEMBLY: Re-insert the panel glass, followed by the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
NOTE: This repair should be done with the door REMOVED from the oven for easier access. To remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can use to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this advice is helpful
Posted on Oct 13, 2010
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
Ge profile spacemaker 1800 xl microwave no heat
The magnetron tube may have died. Not worth repairing unless under warranty.
Feb 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
With outlet power on ...microwave not working ,no indications of signals
Check fuse. If bad test the door switches. Replace bad one and then the fuse.
Dec 01, 2012 | GE Profile Spacemaker XL 1800 36"...
GE Profile Spacemaker xl 1800 JVM1860SD. Touchpad has stopped working.When power is turned on -get error message F3
F3 means you have a shorted membrane keypad.
The keypad is not available as a separate part, so you would have to order a control panel frame assembly, which comes with a new keypad on it.
Whether your model number is JVM1860SD001 or JVM1860SD002, the part number is WB07X10474 and a link to various suppliers is here.
They're not making these anymore, so order while supplies last.
This is a simple DIY job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and carefully move your circuit board into the new frame.
Some connectors on the relays have a lock:
Dec 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
230 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
