Washer wont spin makes loud noise like the motor tries to turn tub but it wont spin
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Posted on Oct 13, 2010
  • Bojob Nov 16, 2010
    This article described my problem perfectly, and the linked article made fixing the problem a relatively easy process. Saved me at least a hundred bucks . . . thanks!!
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Loud grinding noise when drum turns
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 20, 2014 | Asko Washing Machines
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
Drive Motor
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Entering test mode
1) try to go the instr. manual and go to the section troubleshooting they explain this . However if you do not have it download from .
www.manualslib.com
see this causes and fix it.God bless you
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch Assembly If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drain Pump If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Sep 30, 2012 | Washing Machines
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Drum turns slow and makes a loud noise
Check for a garment stuck between the tubs.
Check the direct drive coupling on the motor.
You must remove the cabinet to do this.
Mar 05, 2009 | Kenmore 24032\24036 Top Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Washing Machines Logo
426 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
