My blue ink is printing out black - Office Equipment & Supplies
  • 4,737 Answers
Hmmm.. this is another weird and new issue.. the common issue is Black printing Blue.. Well, let me know with more details.. The model and brand of your printer, operating system installed on your computer, and the condition of the cartridges, whether refilled or not.
Thanks..
Posted on Oct 13, 2010
PF Pro printing pale blue instead of black
you are printing composite black instead of pure black.
Still problem is the print head not getting all inks (may be air, or you didn't remove some seals on the inks/print head.
Nov 07, 2013 | MicroBoards Office Equipment & Supplies
I accidentally filled a 121 black cartridge with blue color yesterday. I have tried to remove the blue color so that to fill a black one but it has failed and when I print, it only print the blue color.I...
Did you remove all the blue ink from the cartridge? It is possible that there is still a small amount left. Just keep on printing until the blue ink runs out and the black ink will replace it.
Oct 27, 2011 | Office Equipment & Supplies
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
When i print a page black ink text thin blue lines appear also a blue ink blob
Method 1:Remove your colour cartridge wen you require only balck ink[The blue lines are often signs of empty cartridge]
Method 2: while printing select 'Use Black Ink Only'
Oct 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function Center® MFC-215C...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
12 people viewed this question
k24674
