Question about Photography
Coastar TR-6BTripod Repair
Yes, its about 20 years old, but in great shape except the plastic support that extends from the center pole to each tripod leg has broken off and cannot be repaired. I'm looking for replacement parts or to know if at least the "head" is salvagable. I have seen that Coastar is no longer in business.
  • ant1239 Aug 08, 2008
    i have a vtr-50RA pro-portable tripod that needs a quick release plate -- can you help
  • chamka Nov 30, 2008
    My Coastar TR-6G is about 25 years old. I also have a broken plastic ring that connects all legs to the center post. Otherwise, tripod is in great shape. Willing to pay for part or offer my tripod.
I have a coastar trypod VTR-65 one of the adjusters to tighten center poll from sliding down. The plastic cap you turn to tighten got broke.I need a replacement anyone know where I can get part for it? I didn't know coaster went out of bisness.
softroll@aol.com
Posted on Aug 21, 2009
I hace a Coastar tripod that is missing the Quick Release but everything else is fine The head is about 1-3/4" square and only one side is beveled. Would you like my tripod or like to sell me your Quick Release head? I don't know a model number of the tripod but it says "Red Accent" on one of the legs. But I hate to throw out something that should still be usable.
dcndoon@sbcglobal.net
Posted on Jul 24, 2008
Manfrotto 804RC2 Tripod head
Hi Shirley
-When you look at the center column you should see a small plastic 'nub' about 1/2" from the bottom.
-When raising the column in preparation to move to the horizontal position this must be depressed or it will not 'pass through' the top casting.
-Once this has occurred the column can be raised enough that it will then freely drop into the horizontal position.
Jul 05, 2013 | Manfrotto Photography
Missing the mounting piece for the camera, can it be purchased
Welcome to FixYa.
Yes you can actually purchased it at your local camera accessories stores. You can also order it via Amazon.com (http://astore.amazon.com/securetransaction-20/search?node=78&keywords=tripod+mounting+piece&x=0&y=0&preview=)
Juts search for the correct mounting piece of your tripod.
Thank you for using FixYa. Have a great day.
jas247
Sep 29, 2011 | Sakar TR-60 Tripod
How to put up a tent- ozark trails 16x12
I have this tent and have successfully put it up a few times. It's a big tent but it's frustrating to put up sometimes. Plan on having several people to help you. I find that it greatly helps if there are a total of 3-4 of you.
The poles are color coded. The center support are red rods. The two side supports are blue with the graphite looking rod that goes through the tent.
Spread the tent out on the ground and try to square it up and make it even. Run the center pole through the top and connect to the curved pieces which then connect to red dot poles on the side. Hoist the whole thing up. Have two people hold those poles for a while.
Get the bue poles into the black couplings and put the graphite looking rod through the tent. It will be a little tight. Hoist the blue poles into position. The bottom of the blue dot poles should be about two feet from the center. They extend outwards at about a 30 degree angle. Keep your center people holding the center poles and let the two blue dot pole section extend outwards. You'll start to see a tent shape. Your center holder people may need to keep and eye on the poles.
Now, start trying to get some stakes in. Work the corners. Once those are in and things start getting tight, it should start to hold on its own. Work all the stakes in and make adjustments to all the poles as necessary.
Extend the red dot poles up until the roof is at the proper height. I tend to do this last.
The fly basic basically clips on into holes on the blue dot poles.
It's kind of a pain to set up but its a big tent and works well once it is up. Good luck.
I took a ton of pictures after I got it up the first time. As I took it down, I shot the pictures. Then, I reverse the order and printed them to a book and now sort of use that as my manual.
Have fun.
May 20, 2010 | Computers & Internet
Need part for Smith Victor Kenlock 60 tripod
I had an old Kenlock 3000 tripod with the same problem. What I did was take some good Scotch Packaging tape and just fold it over and over until it was the same height of the plastic pad that you mentioned. I then used scissors to cut the tape into the same size of the pad, and the placed it into the tripod. It works perfectly now.
Jan 04, 2010 | Smith Victor Photography
Need a quick release shoe for a vtr-60ra tripod made by red accent
They are no longer made, but I can show you how to make one.
Jul 29, 2009 | Photography
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
I have a Coastar VTR-95RA tripod. Three flip locks cracked
Coastar has been out of business for at least 15 years, I do not know of anyone that has those parts since Coastar used shut down and went away. Unfortunately that tripod is no longer usable, unless you can find another with something else broken aned scavage the parts you need. Be careful to mathc the model numbers exactly as there were several different models starting with VTR-9... and they may not all be interchangeable.
Jan 10, 2009 | Photography
Vivitar tripod V900 has a broken friction level
Vivitar has been out of the tripod business for a few years now. They may no longer have the parts. You may be able to find another V900 and scavage the parts. Make sure the model numbers match exactly. The V900SE is a different year and does not share the same parts as the V900.
Jan 01, 2009 | Photography
Photography Logo
1,632 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
