Question about Radio Shack Pro-96 Scanner
This is not my product I have a Rca four band scanner (old) model # 16S400 need a manual for programming freq
    President:
  • 2,761 Answers
The RCA 16S400 is not a programmable scanner. Rather, it's an old (70's) crystal-based scanner that requires one crystal for each frequency. It covers the VHF-low, VHF-high, and UHF bands, and utilizes Regency type crystals. You can do a Google or Yahoo search for the crystals, but eBay is probably the best, and lowest priced source.
Bill B.
Listening in since the 60's
Posted on Oct 13, 2010
Testimonial: "this totally answered my question. I knew it had crystals but did not realize what they did. Thank you so much Bill B. "
Need a manual to program radio freq for a RCA four band veractor tuned scanner, this is not a gps but a radio scanner model # 16S400
Please excuse me if I've already answered your question -- it sounds familiar. The RCA 16S400 is a 70's-vintage crystal based scanner that covers the VHF-Low, VHF-High, and UHF bands using frequency-specific crystals. It is not programmable, but rather requires one crystal for each frequency to be scanned/tuned. It uses Regency-type crystals which can usually be found on eBay at reasonable prices.
Bill B.
Oct 13, 2010 | Radio Shack Pro-96 Scanner
Need freq for scanner for albany ga
Press Manual,enter the channel number, then press MANUAL, enter the FREQUENCY you want including the decimal point, press E to enter,if you make a mistake,press CLR to erase,....You can get the frequency's for your state at www.RadioReferance.com ...hope this was helpful...
Apr 22, 2010 | Uniden BC60XLT Handheld Scanner
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Need help on programing my 20 channel 10 band scanning radio
Here's a link to get the Uniden owner's manual... Look for the grey box in the upper right corner.. this will get you up and running ... You may also want to do a google.com search for " radio frequencies" and " your state here".. that will help you find the local radio freq's.
Here' s the link to the manual
May 30, 2009 | Uniden BC248CLT Base Scanner
Uniden BC350C Scanner
Start by pressing 'band' & select the band that the freq you want to program is within by using the 'up' or 'down' button, then press 'search' , when you see the display getting close to the desired freq, press 'hold' & then use the 'up' & 'down' buttons to zero in on it. Then press 'program', then press 'private' & select the channel you wish to put it on (1-50). Repeat this process as needed. I find it's easier & faster to program all the freqs within a band as you can assign them to whatever channel you wish within the 50 in the private bank, then do the other bands. Hope this clarifies it, good luck. Regards from Community Communications in Wanaque, NJ.
Jul 17, 2008 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Programin the codes in a bc60xlt bearcat scanner
I am not familar with that model scanner but all the uniden radios I have used have direct freq entry......Hit manual button, select what channel you wish to enter it in, hit manual again. Enter the freq desired, then hit enter. That should enter the freq in that channel space. Hit enter again to go to the next channel for programming. Hope this helps.
Mar 19, 2008 | Radio Communications
Scanner(POLICE) Question
Hi, using the manual button, step to channel 1 and enter your freq. including the point then press the E button. You might have to step to the next channel using the manual button again. Enter the next freq. and repeat. WX is the weather bands. Lockout is for locking out a nuisance channel(as an example, if someone's mic stays keyed, and keeps the squelch open).Priority is for any channel whose conversations you don't want to miss, just press the button for the specific channel. That way any time someone keys up on your priority channel, even if it's on another channel talking, will go right to the priority one. Review gives you a readout of the freq you programmed into a specific channel. If you need new or extra freq's check here on this site.
http://www.radioreference.com/apps/db/
** Hope this helps you out, let us know,,, Mechanic
Feb 03, 2008 | Radio Communications
I need to know how to program channels into it
HI again, the 248 is only a 50 channel, do you need this info for the 860? If so, I answered in your other post, but here it is again.
Hi tina33, I have an 860 scanner,and this is how I do it. If there is no freq's in there yet, start on channel 1 and punch in the freq- hit E and it will enter it into the first channel. Hit manual to go to ch 2 and repeat. If you need freq's for your area, go here and search out your state and county and it'll give you a list of freq's for your county.You do not have to add the weather channels as their in there already, just hit the weather button. I use an external antenna on mine as it extends the range and allows me to pick up the cars as well.
If you need a book for your scanner, you can get one here, just print1.gif it out.
http://www.uniden.com/pdf/BC860XLTom.pdf
Hope this helps,, Mechanic
Jan 22, 2008 | Uniden BC248CLT Base Scanner
Programming the BC244CLT
Hi, If I'm reading correctly, that scanner is listed as a 30 channel scanner only. You can pick freq's from 10 different bands. Here's just some of the features listed, hope this answered your question.
Mechanic
FEATURES:
  • Clock/Alarm - Large backlit LCD displays time and features "any button" snooze.
  • 30 Channels - You can program each of these memory channels to store one frequency.
  • 10 Bands - Including all public service bands, 4 "HAM" bands, federal and military land mobile bands.
  • Weather Scan - Automatically scans all national weather service frequencies.
Jan 17, 2008 | Uniden BC244CLT Base Scanner
Radio Shack Pro-96 Scanner Logo
261 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
