Question about Maytag MZD2766GES Side by Side Refrigerator
The ice dispencer keeps backing up and I can't get the ice bucket to come off the freezer door. Help please!!!
    President:
  • 1,891 Answers
Must be a whirlpool / or ka . open the door and let it thaw then remove it and de ice it with hot water . dry ir good and the ice delivery shoot .. spray the dry surfaces wth food grade silcone and this will helt for a while . do this about every 3 mo to prevent this prob . mm
Posted on Oct 24, 2010
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The ice dispencer accumulates ice and clogs the opening. also the dispenser only servers crushed ice even when the cube button is pushed
you have two problems. First the ice build up is because the dispensor door is not closing all the way and the air is causing condensation and freezing.
you will half to find out why the door is not closing. it could be a bad door or the solinoid could be bad.
The second problem is that the solinoid in the back of the freezer is not moving the ice bucket arm.
Common problem is that the solinoid is bad or the plastic arm on the solinoid is broken.
Jan 07, 2010 | Refrigerators
Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Can i put ice in thee ice bucket in my american fridge freezer
you can put ice in the bucket and it will dispense. couple things though. if you use bag ice make sure it isnt wet when you put it in the bucket, the water will leak into the dispenser motor and cause it to short out also the ice will clump up causing the bucket to possibly break. if you are using ice out of a plastic tray dont try to use the crushed ice feature it also c an cause the bucket to possibly break.. peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Maytag MZD2766GES Side by Side Refrigerator Logo
163 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
