Question about Vacuums
How to stain and finish plywood bookshelve - Vacuums
  • 4,341 Answers
Well, you sand perfectly. If not new wood, consider a stain enhancer product. Then try using MINWAX stain, let it completely dry 24 hours or so, and then three coats of Minwax polyurethane, in the sheen (glossyness of your finish) and lightly sand with 280 or so, before the last coat.
Posted on Oct 13, 2010
How can you get rid of wd 40 stain on carpet
Spray the stain with WD-40, wait a minute or two, and then use your regular carpetcleaner or gently cleanse with a sponge and warm, soapy water. Continue until the stain is completely gone.
WD-40 Uses - Amazing Ways to Use WD-40 ' Reader's Digest
www.rd.com/home/cleaning-organizing/13-amazing-uses-for-wd-40/..this is saying you use wd40 to get rid of a wd40 stain. How can you get rid of wd 40 stain on carpet Google Search
Dec 06, 2016 | Vacuums
Tip
Rainbow Vacuum Cleaner
Make sure to rinse or replace the Hepa Filter on your Rainbow Vac. Failure to do so can, and will more than likely, result in burning up the motor!
Check this site out for more information on the Hepa Filter:
http://www.amazon.com/s/?ie=UTF8&keywords=rainbow+hepa+filter&tag=googhydr-20&index=aps&hvadid=4030030497&ref=pd_sl_34u1omclvn_b
Happy Cleaning!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Carpet Cleaning, Rug, Steamer, & Stains
on Dec 02, 2009 | Vacuums
When steaming wood floors leaves floors wet
Kathy if you are talking about hardwood floors you should NOT use any kind of steamer ever on them .
The wood is eighter oak or yellow pine most common however cherry and moghagany on high end houses and used .
But it is all what is called tung and grove and is finished on the top olny with an interior finish that dosn't work well with moisture let alone forceing steam under it it will soak into the bottom of the wood and then the wood will start to cup become uneven on open up .
The best thing you can do if you have this problem let it dry out might take some time weeks or more .
Then rent a floor sander sand it stain it and put at least 3 coats of a polyurthane over it if you use water base poly you will need more coats.
May 08, 2015 | Vacuums
How to get rid of oil stains off a concrete driveway
Hi, you must try some cleaner to remove the stains from concrete driveway. There are many products available in the market but I will suggest you one of the best product which I have seen on YouTube video I am sure it definitely work .
Watch this Video: https://www.youtube.com/watch?v=SQqaTT9eVBE
Mar 18, 2015 | Unknown Oil Grabber Oil Stain Remover
How to clean spots off carpet
It depends on what the spots. They may actually be stains. Spots will come out if you use the correct cleaning process and cleaners but stains are permanent unless bleached or dyed. If you are not sure it may be less expensive to call a professional carpet cleaner that knows what they are doing (not all of them do)
Dec 30, 2013 | Vacuums
How to refinish hardwood floors
Sometimes, you just have to find the help that you need. That being said, you might want to go to Superior Hardwoods, as it will be of great help to you.
Feb 03, 2013 | Vacuums
Would like to remove urine stains on carpet with steamer. Do not have any instructions. Please help
You should not try to remove the stains with the steamer. Removing stains with a steamer can cause a chemical reaction that will bond the urine to the carpet.
Mar 15, 2010 | Electrolux Envirosteamer 370A Canister...
Steam cleaning an oil spot on driveway
Hello gktweets,
Cleaning oil stains off of your driveway will require the right "products". However, if the oil stains are a heavy buildup then you will definately need to steamclean them off first.
What you will need to do is apply a sodium hydroxide based degreasing product (basically most types of degreasers) to the oil stains and let the product sit on the stains for a few days allowing for the degreaser to completely dry.
Then you will want to use a "hot" water pressure washer to steamclean the oil stains off. If you do not have a "hot" pressure washer then a cold water unit will work too just not as effectively.
If you do not have access to a pressure washer at all you should re-coat the oil stains with your degreasing product then scrub with a broom and rinse with a garden hose simultaneously.
After your driveway is completey dry and the oil stains are still minimally present you can apply a dry product known as Bio-Dry. They have videos posted up on you tube as how to purchase and apply the product.
This product will go to work on the leftover stain and will work "over-time" as far as lifting the stain out of your driveway.
You can see before and after pictures here at this site: http://www.DrivewaySteamCleaning.com
Feel free to leave any comments on the site as well, they are much appreciated.
Hope this information helps you.
Jul 26, 2008 | McCulloch MC1275 Steam Vacuum
Vacuums Logo
85 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
