Question about Marantz Reference TT-15S1 Turntable
The tonearm is skipping accross the vinyl. One problem we noticed when trying to find out why was that the tonearm height is off, it's too low. How would you adjust the height of the tonearm using the Marantz model 6025?
djproaudio
  • 515 Answers
SOURCE: turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
Posted on May 13, 2008
  • 3 Answers
SOURCE: Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Posted on Jan 04, 2009
  • 12 Answers
SOURCE: Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
Posted on May 21, 2009
  • 2976 Answers
SOURCE: tonearm skips imediately to center of album
Your needle (stylus) is either worn out or not seated properly. If you continue to try using it without the problem being corrected, it will ruin your records. You can check it to see if it's worn out by dragging your finger over it, lightly, from back to front only. It should feel like a small pin. It should also be seated into the groove on the tonearm. If this doesn't correct the problem, replace it.
Posted on Sep 08, 2009
technical114
  • 1851 Answers
SOURCE: I can't get my Marantz 6025 turntable to turn?
As you Marantz 6025 is a belt drive type turntable, the most possible problem is that the belt has been cut or destroyed. You can check it out before order a new one.
Here is the replacement procedure. Pull up the rubber mat, pull up the platter and find the belt. If the belt is removed from the platter, replace it with the glossy side outward. Pull the platter back at the original position. Turn until one of the 2 big openings come over the motor pulley. With your finger place the belt from the platter at the motor pulley. Pull the rubber mat back. You are ready. Here is a schematic for all the above:
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 13, 2010
I have a technic sl 1200 mk2 , my anti skate is
I gather you don't know how to adjust the tonearm. First put the stylus pressure, and antiskating to zero. Balance the tonearm for a free floating position. Ortofon cartridges will list the stylus pressure, generally 1.5 grams. Dial in the correct pressure, and set the antiskating to the same as the stylus pressure. If you require more assistance, or would like to inquire about repairing your Technics, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 09, 2014 | Audio Players & Recorders
Turntable skips regularly
Once adjusted to the correct weight for the type of cartridge then the arm should only jump on a bad record. If it keeps on jumping then either there is something wrong with the platter, being warped or a bad matt. Or there is something in the mechanism that is causing the jumps. Either of these two causes is possible if it does it in the same position on two different records.
Mar 05, 2014 | Technics Audio Players & Recorders
I have problem with tonearm on my vestax pdx 2000 turntable , no connection with needle , but when I make contacts of the needle wet it sometimes help a bit , but I should do it always to make it work. ...
I'd be checking the weight and height settings of the tonearm. Heres a link to the manual for the deck. There's instructions in there about how to setup up the tonearm properly. Don't be afraid to experiment with it. Just remember, too much weight will wear out your vinyl really quickly. Not enough weight will sound like **** and skip easily. Have fun!
http://www.vestax.com/v/info/support/pdf_players_manuals/VOM-PDX-2000E.pdf
Dec 15, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Skipping
That is correct, your tonearm needs to be replaced.
By adjusting that top screw on the tonearm, you only made the problem worse. It's very hard to realign that screw, as those are machine calibrated, and once tampered with, almost impossible to get back to exact factory settings. We recommend replacement of the entire Technics tonearm.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Gear Repairs
Jun 09, 2009 | Technics SL-1210MK5 Turntable
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
May 04, 2009 | Audio Players & Recorders
Jan 03, 2009 | ION Audio iTTUSB Turntable
Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 11, 2008 | Technics SL-1210MK5 Turntable
1210 Constantly Skipps
More than likely your tonearm is damaged. There is a small screw towards the rear of the tonearm. If you loosen this it may solve your problem. However, please be careful, because once you adjust this screw, it is very hard to get it right. That screw is known as a 'conical' screw, and has a cone shaped tip. This tip sits on top of 4 very small ball bearings, which are held in place by a very thin piece of sheet metal. If any of these are damaged, you will have to replace the tonearm. If they are not damaged, and your conical screw just became misaligned, then it is possible to salvage your tonearm. However, be very careful when turning this screw. Turn it counterclockwise very slowly, about a hair of a turn... yes, I said a HAIR of a turn. Then put the needle back on the record and observe what happens. If the problem persists, turn it a little bit more. Keep doing it until the problem is solved. You will eventually have to have the tonearm replaced, as this screw will start to loosen over time, once it's been adjusted.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 27, 2008 | Technics SL-1210 Turntable
Turntable skips during playback
- DJ PRO LAB
www.DJPROLAB.com
May 12, 2008 | Technics SL-1200MK2 Turntable
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
Marantz Reference TT-15S1 Turntable Logo
155 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
