Question about Fisher and Paykel GWL11 Top Load Washer
Main problem, I have no manual and no clue how to 'program' washer, plus, no hot water ever comes into the machine, no matter what button I press.
My aqua smart washing machine wont fill with water to the maximum for a large load
Posted on Jun 25, 2011
  • 3,230 Answers
Well first of all you may please download the user manual for your machine from the link below -
http://laundry.manualsonline.com/manuals/mfg/fisher_paykel/gwl11.html
If after following the user manual you have the same problem then please tell us about it.
Good Luck!!
Thanks for using FixYa!
Posted on Oct 13, 2010
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Miele CVA610 error reads expel air but when we do as manual suggests (run hot water & milk frother) no water comes out.
- Make sure that the filled water container is in the appliance.
- Turn the program selector to "On" with lighting and place a container under the hot water spout and another
under the steam spout.
- Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in
quiet, continuous streams.
- Press the hot water button again.
Turn the steam selector clockwise to o, to turn off the water.
If this doesn't do it for you, you are doing it wrong!
Oct 06, 2009 | Miele CVA610
Only one of the wash cycles on my Maytag Neptune TL washer still works. Nothing happens when you press the other buttons. Most of the lights for the additional options are out too (e.g. water temperature -...
Is it a FAV6800AW or FAV9800AW machine? Sounds like it is. I believe you have a Control Board issue; the Control Board has a 5yr warranty. Do you want to DIY a fix or call in a Appliance Repair Tech? Have you reset the 120VAC power on the machine? If not give the Control Board a hard reset by pulling the washer power plug for 10 seconds or so and then re-power up the machine.
I’ll attach the Service Manual link located on this site for reference. See if you can get into Service Mode, try this.
To enter Service Mode, this from the SM.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys simultaneously for three seconds or until the control beeps. The Console display will show “00”.
Access Board Output Test by pressing the Delicates key. The console display will show “ot”
The lid lock will lock and the Quick Wash LED will be lit. Will the machine allow you into Service Mode? If not then it’s time to replace the Control Board. Press the Off button to back out of Service Mode.
Let me know what direction you want to go. Rich
Jul 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error codes on Kenmore Elite washer
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
while F09 is the water pump. It usually means something is clogging it. Take the front cover off of the washer and the water pump is located right in the middle front. Unscrew the cover to the pump and make sure there is nothing clogging it.
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Mar 08, 2009 | Kenmore HE2 Plus Front Load Washer
Nead help pleace
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 15, 2009 | Saeco Royal Digital Plus Coffee...
Machine says ventilate
Jan 11, 2009 | Saeco Royal Digital Plus Coffee...
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
LG Tromm hot water only
i have found the water inlet valve bad and also the main control board can cause it
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
156 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
