Am using windows vista and am trying to burn dvds with realplayer and at the last second of burn it fails and says error 2131042562, very annoying as it takes nearly two hours to download and it fails at the last minute.
    Scholar:
  • 85 Answers
This is a driver problem. I had it as well. Go to your PC manufacturer web site, support, downloads, put in your model number, your operating system and scroll down the drivers until you find your optical equipment. Trouble is, there may be more than one drivers. Download them all and install them; your computer will know which one is which.
Posted on Oct 13, 2010
Can burn dvds but cant burn music cds
All or any music formats? What format is the music file? Use you Real Player Converter to convert the format. Is it DRM music that does not allow copying?
Dec 08, 2012 | Computers & Internet
Error Code 0x80004005 while trying to delete RealPlayer files
May be there is some prob with your OS. Before reinstalling that, i suggest you download & install a freeware called Unlocker. It unlocks the files & helps delete them easily. Google Unlocker & install that. Its a must have utility.
Jul 07, 2012 | RealNetworks RealPlayer Beta
While I was trying to burn a back up recovery disk for my emachine's windows vista, emachine didn't come with one, but a program on it to install one. I was told to use 10 writeable cd's or 2 dvds, i...
The problem here is that when disk burners stopped being $400 each, the quality went way down. What's likely happening is that your burner is sucumbing to an alignment or heat-related issue. My gut feeling tells me that you should do the burn, then wait about an hour (maybe two) and do the second disk so the electronics and mechanical parts have time to cool off.
[rant] The real issue in your case is that eMachine's recovery system is an after-thought. Any well thought-out system would let you select which disk to burn or give you the option to make ISOs so you could burn them on another machine. More importantly, they should just let you do this to an 8GB USB stick and call it a day. I would avoid machine that can't be bothered to give you an easy way to recover their machines, then give you the responsibility of creating the recovery media on sub-par hardware. [/rant]
Anyway, let me know how it works out.
Feb 28, 2011 | Computers & Internet
When I try to burn dvds in Realplayer Plus SP, the error "Internal Software Error" pops up & burning fails.. I paid money I didn't even havr to spare for this so I'm very frustrating over losing my...
try using a burning program wothy of the attempt.real player works off a basic set of drivers and fails on many occasions. if your burning from dvd to dvd use dvdfab version 5.0 or higher. this will right past any copyrights. or if burning from files use nero version 7.0 or higher. anything less is a waist of time.
Jul 04, 2009 | QPS Que! Fire CD-RW Burner
When i click on burn from the windows dvd maker an error message comes up indicating that my blank media is not recordable. I have tried using dvd-r and dvd+r.
Try to use different program to burn your dvds, try to use Nero, but this msg also means that Your DVd drive is not burner double check from the device manager if its says read only this means it cannot burn, it has to say write too.
Mar 14, 2009 | Microsoft Windows Vista Home Premium with...
Burning dvds with realplayer
DVD discs come in two capacity sizes.
Single layer DVD have a capacity of 4.7 Gb
Dual layer DVD have a capacity of 8.5 Gb
Some DVD burners are single layer burners only and cannot burn dual layer discs.
The error message you are getting would indicate that the disc you are using is not large enough to copy all your program material.
Jan 25, 2009 | Ahead Software Nero 6 Ultra Edition...
Problem burning DVDs
This happened to me also. I fixed the problem by buying new DVD discs, sometimes the mac's rom doesnt like particular discs. Its a trial and error thing with which ones it will use. Make sure you are using the latest version of Roxio toast to burn with, also make sure your ROM is DVD-R.
If all this fails, it could be your writer in the rom. Try burning a CD, if that works it will be the above problems.
Try using discs with a GOLD BOTTOM, it seemed to work for me.
May 06, 2008 | Apple Power Mac G5 Desktop
Unable to burn using a LG GSA H58N DVD burner
With the built in drivers for windows XP it can identify and use DVD-RW facilities of DVD burner. However depending on your bios your machine can fail to burn DVDs if your bios can not recognise that output.
While loading the CD that comes with the DVD-RW did you get an error message if yes then it means you BIOS is failing to recognise your DVD-RW as an output method try to update the BIOS. But before you do that if you can try adding the drive on a modern (after 2002) machine with xp and see if it can burn DVDs there without adding any drivers.
if it fails on that other machine then you can be sure its not your BIOS but a problem with drive (which I suspect most actually). But if it works then then you need to update your machine bios.
Mar 25, 2008 | Computers & Internet
Can't burn DVDs (VistaHomePrem)
Well I am not surprised ya can't get it to work.. It can all be quite confusing.... I suggest that you try some "Other" burning software. I recommend CopytoDVD...AnyDVD ... convertXtoDVD.... vso-copytodvd.en.softonic.com/ OR AnyDVD www.slysoft.com/en/download.html ConvertXtoDVD vso-convertxtodvd.en.softonic.com See one has to have a program that will "Burn" in a Format suitable for ALL players PC & stand alone DVD's the ones I have listed Just work... ensure you read the "Help" files and B4 long ya will be watching DVD's.
Sep 05, 2007 | Toshiba Satellite P105-S6207 Laptop
Computers & Internet Logo
299 people viewed this question
David Payne
David Payne
