Question about Toshiba e-Studio 350 Copier
Receiving faxed We need to be able to receive faxes 24 hours a day, but on the weekends the copier turns off due to the energy saver mode. I see that I can change the minutes for delaying the turn off, but don't see how to disable it so it will always receive faxes.
  • btdt1st Sep 11, 2008
    I have the same problem with the auto power off on our Toshiba e-studio 650. I tried resolving it using the same key strokes as mentioned for the e-studio 350. Any suggestions would be appreciated.
Hwo can i find a free manual handbook for e-45
Posted on Jul 05, 2008
  • 43 Answers
When the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Posted on Jun 02, 2008
My fax machine will send a fax, but I can't receive a fax?
The fax machine may be in secure receiving mode. The following is from the User's Manual section on Faxing. downloadcenter samsung com
Receiving in secure receiving mode
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Activating secure receiving mode
  1. Press btn_fax.png(Fax) on the control panel.
  2. Press Menu until Advanced Fax appear.
  3. Press the left/right arrow until Secure Receive appear and press OK.
  4. Press the left/right arrow until On appear and press OK.
  5. Enter a four-digit password you want to use and press OK.
    You can activate secure receiving mode without setting a password, but cannot protect your faxes.
  6. Re-enter the password to confirm it and press OK.
  7. Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received.
Printing received faxes
  1. Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
  2. Press the left/right arrow until Print appear and press OK.
  3. Enter the four-digit password and press OK.
    The machine prints all of the faxes stored in memory.
Deactivating secure receiving mode
  2. Press the left/right arrow until Off appear and press OK.
    The mode is deactivated and the machine prints all faxes stored in memory.
  4. Press Stop/Clear to return to ready mode."
Feb 10, 2015 | Samsung SF-650 Laser Fax/Copier
NEED DIRECTIONS TO TURN ON FAX RECEIVING MODE
press menu and fax function and choose tel,tel/fax or fax
May 24, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Not receiving fax- line is busy to all senders
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 12, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Stopped receiving faxes ten days ago. Can still send faxes. Senders say it just rings and rings. Calling the fax by phone confirms many rings, then fax belltones. What do you think is the problem?
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 28, 2010 | Canon PIXMA MX310 All-In-One Printer
The Brother FAX 4100e says "sleep" all the time, though it seems to work okay. Is this right?
that's an energy saver function. If your fax is sending and receiving fine, then take it as a money saver :)
Hope this helps.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
DX-800 is locked up, it says "receiving a message"
Unplug fax machine
Hold down ENERGY SAVER key while plugging back in.
Scroll down to ALL JOB CLEAR
press SET
Wait for reboot
No joy?
Replace the main board.
Jul 23, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Fax received goes directly into memory of the machine my mchine is samsung SCX 4521F
Good day Sir,
If you don't want other people to view your received documents, you can use Secure Receiving mode. In this mode, all of the received faxes are stored in the memory.
To turn Secure Receiving mode OFF:
  1. Press menu until "Advance Fax" appears on the top line of the display.
  2. Press the scroll button < or > until "Secure Receive" appears on the button line and press Enter.
  3. Press the scroll button < or > to display 'Off" on the bottom line and press Enter.
  4. Enter the 4-digit password and press Enter.
5. To return to standby mode, press Stop/Clear.
Have a nice Day and God bless.
Apr 16, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Sleepy fax
Scroll through the SETUP menus, look for ENERGY SAVER or SLEEP
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Fax
HI,
u need to make change to answer ring pattern from the front panel of unit .
Set the fax function to answer the phone automatically by pressing the auto answer mode button on front panel .
Thanks
Jun 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Canon Image runner 1670F will NOT receive faxes
scroll through menu and look for powersave options using keypad and display
Jan 15, 2008 | Canon ImageRUNNER 1670F Copier
Toshiba e-Studio 350 Copier Logo
173 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
