Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirpool Cambrio Has A F1 Code - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 3,230 Answers
Well error F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed.
First of all you may leave unplugging the washer from the wall, leave it unplugged for a while. That may reset the internal computer chip. If further you have the same problem then it need some part (chip) replacement need some skills of electronics, part is $150 CODE 083009 part W10189966 CNTRL-ELEC. Post comments for further help or information...........
Good Luck!!
Thanks for using FixYa!!
Posted on Oct 13, 2010
Keep getting F1 error code on my cabrio whirpool top load washer. Can you help?
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control board and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Sep 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hey can give me an answer for my whiroppol washer
MY WHIRPOOL WASHER HAS A CODE F2 AND F1 IT WONT RINSE ONLY WASHES THERE IS WATER IN IT PLEAS TELL ME WHAT TO DO?
Aug 06, 2011 | Whirlpool Washing Machines
OUR WHIRLPOOL/CABRIO MODEL WTW6600SW2 IS FLASHING F1. WHAT IS PROBLEM?
Lool on this site for F1 fault. Apparently a very known problem, seems with control pcb. I called Whirpool today on a machine purchased in 4/07 with a 4 year extended warrenty from Lowes, and they didn't even question it. Said a repairman would be out to replace part and parts and labor are covered by Whirpool. Call them at their 1800 #, Mention it's the infamous F1 fault, have model and seriel # at rear of top load door ready for the technical help person, and they'll take care of it.
Dec 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I just had the panel rewired fro f51 now i have f1
F1 is a primary control failure. When I get my F1 I hit pause/clear and then start - it usally begins its cylce then bumps back to F1. If I do this about 3-7 time it will clear. Then on rinse we go again. Some days I have a 3-F1 restart and somedays it is a 7-F1 restart. Just depends on the day. No rhyme or reason. I know I have to replace the main circuit board but $160 + labor is not what I want to do, so I fuss over the F1 and move on.
Feb 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Only runs 2 mins then shows F and i clear it try to restart it it will start to fill then shows sd
Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
When the cycle starts F1 appears on the dial,
Here is a link to the service repair sheet at Whirpool for the F1 error code on your machine. You will find 4 things to check at the bottom of the page. Good luck.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/1a4cb9c9ab426640852574e90050e40f/$FILE/8178767.pdf
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore oven F1 error code
I have a whirpool oven that won't self clean anymore and it comes up with a FSE 1 error which is a factory service error and the code is a 1 . You need to call them to come out and have a tech fix it as it's digital
Mar 10, 2009 | Ovens
F1 error code on cabrio washer
Call Whirlpool at 800-253-1301 in USA. There is a recall on this washer for the F1 code. Service call and parts are free. I just did it today.
Jan 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal De
