Question about HP Pavilion zd8000 Notebook
My display screen is no longer working. I'm assuming that's the problem since I can hook it up to an external monitor and get a picture. Is that something that can be repaired?
  • 109 Answers
It will be the inverter or the backlight. i am working with laptops every day and HP laptops with this problem are very comon. most of the times it is the inverter or the lcd, sometimes this is just a small pcb that needs to be replaced, but in some caes you will need a new screen. sorry for the bad news. get to your local pc repair shop or the retailer and see how you get on.
Posted on Oct 13, 2010
Where can i find a display screen for my acer liqiud mini e310? all what i find when i search is touch screens and i want the display one!
I'm assuming you want to hook up an external monitor? If that is the case than any with a VGA hook up, which is most monitors will work. You simply plug in the VGA cable from the netbooks vga port to the port on the monitor. You will need to from the FN key + one of the F# keys that says LCD or has a monitor icon. You can toggle to netbook only, netbook + external mirrored, external only. You can also configure it for extended display and use both displays at the same time.
Monitor Link
Jan 26, 2013 | Acer Computers & Internet
My laptop comes on, and the screen stays blank, (black ) nothing, I tried hooking up an external monitor but it does nothing also, could the invertor be the cause? Unit is a Sony VAIO PCG-TR3A
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
Dec 09, 2010 | Sony VAIO PCG-TR3AP1 Notebook
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
No monitor screen but i have a picture hooked up to external screen
I will assume that you mean there is no picture on the LCD screen on the computer but it works on an external monitor. I have a tip which explains what you need to do at http://www.fixya.com/support/r4282435-replace_inverter_board_in_laptop_screen It also lists where to get parts and other information you may need. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 07, 2010 | Compaq Computers & Internet
Screen is black..will not display anything. Any
You provided very little information, so I'll try to answer:
I assume you turned on the comptuer and it seems to be working-you didn't say.
I assume it used to display something-you didn't say.
Hook it up to an external monitor. Can you see something? If so, one of two things are wrong: Your LCD screen has gone bad OR you need to hit the Fn/Special function key combo that moves the display from your LCD to an external monitor.
If none of these solves the problem, then your video card has gone south on you.
Jan 23, 2010 | Toshiba Computers & Internet
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Screen does not work on my latitude c840
If your LCD screen on the laptop does not display a picture and if you hook up an external monitor and it doesn't display anything either, then your video card is bad.
But--before you go trash the thing, when you hooked up the external monitor, did you push the Fn key and the corresponding special function key at the top of the keyboard that switches the output to the external screen? (It does not just display to the external screen without you telling it to.
What your uncle describes is a problem with the laptop LCD monitor, not the video card.
Jul 09, 2009 | Dell Computers & Internet
No picture
If you mean you hooked up an external monitor and you want to see the display there. Well there should be a Fn key combo to toggle the displays. It should be one of the keys that looks like a monitor plus the Fn key at the same time. Otherwise go into the Control Panel -> Display -> Settings and you can switch to the other monitor there. Hope this helps.
Jan 18, 2009 | HP Compaq Presario v4000 Notebook
My Hp PAvilion DV9000 LAptops screen keeps going blank. If I hook it up to and external monitor then it works.
YOUR INTERAL DISPLAY ADAPTOR MAY BE GOING BAD, HAVE U TRIED REINSTALLING THE DRIVER , IF SO ITS UR ADAPTOR OR THE SCREEN ITSELF WHICH IS NOT A BIG PROBLEM REPLACING. THE EASIEST THING TO DO IS ASSUME ITS THE MONITOR. DOES IT DO THIS IMMEDIATELY OR DOES IT TAKE A WHILE. WHEN U HOOK UP THE OTHER MONITOR DO BOTH SCREENS WORK.
Aug 04, 2008 | Computers & Internet
Trouble hooking external Viewsonic monitor to Toshiba laptop
If I understand You are using a Monitor connecting the Monitor...
and the background is shared byboth the display however the Cursor stays only on one of them at a time.However it can be toggled among the 2.
If yes,
then this Feature is called the Extended Display.
Use the same Key Combination that you would use for external Display one More time and it should Work.
Jul 03, 2008 | ViewSonic VX924 19" LCD Monitor
HP Pavilion zd8000 Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
