Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a mcc1840b pull start wont grab,rope just pulls out easy !
  • rouse1961 Oct 19, 2010
    can you tell me where to buy the pull system, online! thanks for the info..................
  • 7,733 Answers
Change the rope pull system.It comes in a one piece and is easy to install.
Posted on Oct 14, 2010
When I pull start rope on my Craftsman 32cc 4 cycle weedeater . . . engine does not turn over . . . when I let go of the rope and it retracts . . . what is wrong?
There are 2 dogs or fingers that expand out to grab the flywheel when the rope is pulled They are sticking and can not expand or slide out. Remove the recoil unit and free them up When the recoil unit is off pull the rope and watch the action
Jun 08, 2015 | Craftsman Garden
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
I have pulled the cord out of my gas powered trimmer. What is the easiest way to fix this
Remove the pull start mechanism, remove the old rope from the inside plastic, thread a new rope through the hole in the outside and through the hole in the plastic center where you removed the old rope, Now reach between the spool and the edge of the casing and pull some slack in the rope, there will be a notch in the spool, set the rope into the notch and begin spinning the spool to make tension in the spring ( correct direction is the same way the rope is spooled in. go until you have good tension on spring, grab rope left outside casing and pull through, then let rope get pulled into the spool with the spring tension you have created. Now just reattach the handle.
May 31, 2010 | Craftsman 22" Gas Hedge Trimmer
The starter pull cord has pulled off.
EASY,REMOVE TOP COVER OF ENGINE THAT HOUSES ROPE ASSY. LOOK UNDERNEATH PLASTIC PIECE,CUT THE KNOT OFF THAT COMES THROUGH HOLE AND PULL AND EXISTANT ROPE OUT. OK, GET NEW ROPE AND HANDLE TOGETHER,THE END THAT IS OPPOSITE FROM NEW PULL STRING HANDLE YOU ARE GOING TO USE. CAREFULLY WIND UP ROPE HOUSING NICE AND FIRM JUST BY WINDING IT UP WITH HAND IN AS IT SITS IN TOP COVER. WHEN YOU THINK IT HAS ENOUGH TO PULL ROPE IN FEED END OF ROPE IN HOLE AND IN CHANNEL OF ROPE HOUSING,THERE IS A SMALL HOLE TO LINE IT UP WITH,WHEN SEE THE ROPE END FEED IT THROUGH THAT HOLE NOW. MAKE TAKE ANOTHER SET OF HANDS OR A WEDGE TO STOP RETRACTING OF SPRING. PULL ROPE THROUGH AND TIE A DOUBLE KNOT AT END SO IT WONT PULL THROUGH. SLOWLY LET IT PULL ROPE IN,THEN PULL ROPE BY HANDLE FULL LENGTH TO ENSURE ALL KINKS ARE OUT AND IT PULLS BACK IN LIKE IT SHOULD.
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
Wont start
frist thing did you check the flywheel key, if it is sheared its out of time, it will pull back hard .
Jul 01, 2009 | Garden
When pulling the rope to start it doesn't grab for about 5-6 pull
Unscrew the 3 or 4 screws on the outside of the plate that is part of the pull string housing, there are 2 centrifugal pegs that are sticking due to trimmings getting in that area. Inspect, and clean the pegs that fly out when you pull the string. Do not oil (that will only attract more junk later), make sure they are free, and come out when you pull the string. And your problem will be solved.
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
How do you adjust the valeo speed jump rope for your height?
It's simple, really.
At each end of the handles, you'll see a black cap. You can use a flathead screwdriver to go right in the crack of it, and pop it out. You then take the black rope, pull it out, and move down the silver piece until it fits your height. If you're like me, you'll need to cut some of the rope so it will fit in the handle. After you have adjusted it to the right height, snap the black caps back in.
Feb 19, 2009 | Valeo Speed Jump Rope 1 Pk
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
144 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
