Question about ASUS A7N8X-X Motherboard
Motherboard will not fire up i get no monitor activity at all, i have tried memory,cpu and grapics card on another board and they all work,have changed power unit as the fans were running slow,this all started when the on off button got stuck down and i flicked it in and out a few times,then it shut down, restarts with no picture, i have reset the bios with the jumper also removed thebattery. hope you can help thanks ron
    Scholar:
  • 38 Answers
Sounds like you an overcharged capacitor or a short to an integral part of the board. unless you have the expertise or tools to pinpoint where the error has occurred this will be a hard fix. If the board is still under warranty I would advise getting in contact with Asus themselves to see about getting a new board sent your direction.
Asus support number: (510) 739-3777
Posted on Oct 13, 2010
I am getting a message that there is no signal to my monitor from my cisnet computer. I have tried replacing the motherboard and upgrading the ram. The monitor works with my other computers. What else...
irst check the cable from the monitor is firmly connected to the graphics ports in the rear panel of the cpu tighten the two screws of the connector if you still have the problem then check the connector for any pin breakage if no pin breakage try adding an add on grapics card to the pci,agp or pci exp which is available in your motherboard if there is display then the problem is with connector in the motherboard
Oct 30, 2011 | ZT Group CISNET A7050 PC Desktop
MY GRAPIC MEMORY IS 128MB.MY BOARD IS DG31GL CAN I BUILT ADDITINOL GRAPIC CARD LIKE GT NVIDA,OR OTHER ON THIS BORD PLS TELL ME.
No, you motherboard doesn't have a separate video slot in which to plug another video card.
Aug 03, 2010 | Computers & Internet
My monitor is not booting up and the light at the front of the tower remains on.The power light on the monitor flashes continually. If the reset knob is pressed the light on the tower will go off and the...
There could be many things that could stop the board from booting, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, graphics card (if required) and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or the motherboard. The next step is to replace each one of the first five with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck
Thanks
Mark
Jan 31, 2010 | Biostar U8668D (802700113338) Motherboard
Hi! I have a pc with abit is7-e2 motherboard.. And when i start the pc a red led turns on the board... There is no picture on the screen. I already checked the video card but its working
Just how did you check the video card if you get no image on the screen?
Try another monitor with your computer. If you still get no image, then it's your video card or another component.
If your computer will not pass the POST (power on self test) then you will not get any video output.
Culprits can be the hard drive, the CD, the memory, the motherboard, or the CPU. I would disconnect everything but the CPU, memory, and video and try to start it to narrow the problem. But first, try another monitor.
I've even seen a bad power supply that seems to work keep the video from working.
Jan 16, 2010 | Abit IS7-E2 Motherboard
No signal from monitor, help!
do u have a video card? or your monitor in connected in tou integrated grapics port? (i.e. in *********** board.) maybe your bios is set up in booting up on iether of its two and your monitor is connected to a different. try connecting it from the two, while booting up.
Aug 17, 2009 | Abit IP35P Motherboard
Gateway gt4016 won't boot. Fan runs but nothing else
Try a different CPU. and also try a completely different set of know good memory. If after this the system still doesn't boot up then then the motherboard they installed in defective and if that the case? Get your money back.
Jun 16, 2009 | Gateway GT4016 Desktop PC
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
No display whatsoever.
it doesnt sound like the moniter if you have tried switching.you might wanna check memory is securely fitted also.
Mar 02, 2008 | Everex StepNote NC1500 Notebook
ASUS A7N8X-X Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
