My new epson workforce 1100 printer stopped working when I replaced the ink cartridges the first time. Both paper and ink lights are flashing. In the printer maintence manual, it says the print heads have reached the end of their useful life. But this can't be possible. Can you help me reset it.
issy2
  • 460 Answers
SOURCE: Epson Stylus Photo R220 InkJet Problem
this sounds like ur both cartridges are empty...
Posted on Sep 09, 2008
aicaxz
  • 511 Answers
SOURCE: 2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
Reset waste ink counter. Find at indoreset.blogspot.com
Posted on Jun 03, 2009
  • 11 Answers
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Posted on Jul 07, 2009
  • 5063 Answers
SOURCE: Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
Posted on Jan 29, 2010
nadirsalim
  • 185 Answers
SOURCE: i just refilled my epson 310 workforce ink
Most of Epson cartridges have chips and when a counter in the printer reaches a certain limit, it writes into that chip so it won't be used again. So you need a chip reset device. (around $15)
good luck
Posted on Nov 22, 2010
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
My workforce WF-3540 displays "PAPER JAM". I can find no jam
This sounds weird but I will post it since is solved this problem for me. Despite following all the instructions I could not get rid of the "paper jam" message on my WF3540 . In desperation I tried changing the yellow ink cartridge (which was low) and after the printer went through all its "new cartridge" routine - lo and behold the paper jam message was gone and the printer worked!
Sep 25, 2013 | Epson Workforce 1100 InkJet Plotter...
Epson workforce 1100 flashing lights
please help me to find epson office me 1100 resseter
Jun 13, 2012 | Epson Workforce 1100 InkJet Plotter...
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I have an Epson Stylus Office T1100 printer. I just replaced both black ink cartridges with their recommended replacement cartridges (73N) but the printer insists that one of the cartridges is not a...
Sounds like there is a problem with the printer cartridge. Simplest solution would be to return it to the point of purchase for a replacement.
Did you mean you have an Epson WorkForce 1100 Wide-format Printer?
If you think the problem is with your printer then you could work through the installation procedures to make sure you have done it correctly.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=130785&prodoid=63084675&foid=148017
Dec 10, 2010 | Epson Stylus Photo R200 InkJet Printer
Both ink and paper lights are flashing, printer will not print, installed new ink cartridges for all colors.
the waste ink tank beneath the printer is full. it will cost more to fix this than a new printer. take a look at the Epson NX and Workforce series and get yourself a good printer with a year fedex replacement warranty.
Jul 04, 2009 | Epson Stylus Photo R220 InkJet Printer
I have brought a replacement cartridge (black) for the Epson D92 stylus printer I folowed the usuel steps and sucsesfully printed 4 or 5 b&w pages now the printer does not seem to except the cartridge...
This may or may not work on your model
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
The Protection Counter referred to above prevents you from printing once the printed pages counter reaches a predetermined threshold.
If this doesn't work, let me know.
Regards,
Worldvet
Nov 11, 2008 | Office Equipment & Supplies
157 people viewed this question
k24674
