Question about GE WSXH208A Front Load Washer
My front loader shakes.. when in the wash and spin cycle
  • GE Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Oct 13, 2010
Kenmore top loader shakes in spin cycle
Level the machine front to back and side to side. The legs screw in for proper leveling. This will stop it from shaking.
Oct 12, 2014 | Washing Machines
Front loader kenmore he2plus rocks the house on spin cycle?
make sure the unit is totally level on all4 corners if this dont cure it make sure there arent any shipping bolts toward the bottom that were supposed to be removed after installing that are still on them they will have a yellow or red tag that will say remove after shipping hope this helps
Feb 25, 2010 | Kenmore HE2 Plus Front Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Very loud shaking during spin cycle
assuming it is a front loader. Check if transport bolts are not still attatched. If not, open back cover and look for shocks for breakage or being siszed. Do you have a noise from the drum while spinning and having no load. If so, the bearings need to be replaced.
Sep 16, 2009 | Maytag MAH8700A Front Load Washer
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
142 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
