Question about Maytag Refrigerators
Refrigerator maytag side by side MCD2257HEB
Electronic dual control display went to dashes and no numbers. Could not adjust numbers. Unplugged it and then turned it back on and it started to run again
  • 114 Answers
SOURCE: bad electronic control
Replace it if it is defective.
Posted on Sep 28, 2007
  • 1314 Answers
SOURCE: Amana Temp Controls Stop Working - Show Dash - Food Spoiled
could be a glitch in the defrost cycle the adaptive defrost control could be faulty and when you unplugged it you might have reset it it should be ok till monday but i would just get the basics untill the tech looks at it
Posted on Jan 26, 2008
SOURCE: Avanti Compact Refrigerator Mod.#18ERC/RW
I am about to purchase one of these--Have you found a solution yet??
Posted on Oct 06, 2008
farfield
  • 462 Answers
SOURCE: Refrigerator stopped working / only makes a dull clicking noise
Your Compressor is not running and the overload is the tick click I'm believing follow these steps below to help you decide:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} . To Decide if Either your compressor is broken inside or the start components are not working properly.
Parameters’ are as follows and must MUST be true before continuing:
1 Condencer coil (outside coil) Clean and open for a ir flow
2 Condensor Fan motor is running and turning at enough speed and correct direction.
3 Voltage to the compressor is correct and supplied.
4 Decide if the compressor is Hot or warm or cold to the touch for future reference.
Cold or Hot
Could it be the compressor not running or that it has overloaded?
If you suspect the compressor try to follow this to decide your next step:
These little helps allow you to get the compressor running or decide that it needs replacing
1 Ohm the compressor terminals to ground and across to each other.
A. If any read anything to ground the compressor is bad. No Need to go further.
B. If the compressor is hot and you read through some points on the compressor motor (pins or terminals) but not through others wait up to 24 hours for an internal over load to reset. Internal type, usually AC and larger Refrigeration Compressors. Smaller refrigerator type compressors have an external over load. After 24 hours off or yours has an external overload re-ohm and see if all have readings to each other. If these read open IE No resistance between each other the compressor is bad.
Results your looking for:
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
After 3 or 4 tries if the results don’t add up the compressor motor is bad. Replacement is required. Is this machine worth a new compressor? Is it still under warranty? Is the labor and all parts covered?
2 Assuming the above checks out:
Get a new Start relay (start capacitor if so equipped) relay and overload (and run capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration..
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 18, 2009
  • 1891 Answers
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Posted on Apr 19, 2010
Testimonial: "Thank you. We will work on that and see what happens. "
Service mode for Maytag MFX2570AEM3 refrigerator
How to enter service test mode in a Maytag refrigerator with electronic controls
Service Test Mode:
The service test functions are performed using the refrigerator display and keypad.
Enter the Service Test Mode by performing the following sequence of events.
1. Open the Fresh Food door and press and hold the Door Alarm keypad DoorAlarm .
2. Press and hold Refrigerator Temperature UP keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. Press the Refrigerator UP Keypad again.
5. Display will show 001 in left display and numeric or dashes in right display.
6. Press Freezer Up keypad and Freezer Down keypad to toggle through Service Test numbers.
hope this helps.
also may find more info at repairclinic.com site
Jan 10, 2018 | Maytag Washing Machines
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Where are the refrigerator fuses located for a Maytag msd2652keb
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are no fuses in refrigerators. Individual component failure acts a fuse.
You are locked into defrost.
PART NUMBER: 67004704 - Cost: $116.00
This is located in the upper right inside your control box.
This replacement adaptive defrost control board (part number 67004704) fits several models of side-by-side refrigerators. The adaptive defrost control board starts and stops defrost cycles as the temperature of the evaporator rises and falls instead of on a set schedule.
Shut off the circuit breaker for the refrigerator before beginning this repair. Also make sure you're well grounded (Rub hands on bare metal), because electronic components can be damaged by discharges of static electricity. The board installs behind the digital display in the control panel. Procedures for removing the existing adaptive defrost control board and installing the new one vary among models.
Dec 07, 2014 | Maytag Refrigerators
Water dispenser
I would check for a bad MicroSwitch
Oct 29, 2013 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
I replaced Refrigerator Electronic Control hv board and I can't program it successfully? DOthe doors need to be open to program?
Aug 13, 2011 | Maytag Refrigerators
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I adjust the water level on ice cube filler?
If your model is the PSW26P the ice maker is electronic and not adjustable. The ice maker does set time for water flow so if there is a problem with water valve or supply line then the time has no meaning. The part number for ice maker is WR30X10093 and part number for the dual water control valve is WR57X10032 So the water flow is too little or too much?I will be here if you need me, Thanks Sea Breeze
Mar 19, 2010 | GE Profile PSW26P Stainless Steel Side by...
Electronic temperature controls
the board got fried needs to be repl if you are capable repl if not call a tech my number is on the tech list you can call me
Oct 16, 2008 | Kenmore 50522 / 50524 Side by Side...
Both compartments not cooling
It sounds like the control board may be gone. If there are no fans running or the compressor running then it will never cool of course. I don't think it's stuck in defrost mode since you say the display shows dashes vice numbers. Go to this site for diagrams, etc. Item 11 is the controls section. http://tinyurl.com/3533ao
Jan 28, 2007 | Maytag MCD2257HES Side by Side...
Refrigerators Logo
67 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
