Question about Haier HTQ21JAAWW Top Freezer Refrigerator
The whole fridge is not cooling. what are the first steps to troubleshoot a fridge? HTQ21JAAWW
  • Haier Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
My 3yo Haier HTQ21jaaww refrigerator no longer cools. The coils have been cleaned to no avail. Help I have a big family and need my fridge!!!
things to ck . is the compressor running ? remove back the comp will feel hot if running . if its running it may have lost its gas .. / if not running but the cooling fans are . the relay on the compresser may have failed .. hope htis elps mm .. feed back pls ..
Jul 10, 2011 | Haier HTQ21JAAWW Top Freezer Refrigerator
The whole fridge compartment is not cooling, but the freezer compartment is working fine!?
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution
Jul 01, 2011 | Refrigerators
Frost builds up on freezer walls. I have lubricated the gasket and defrosted the freezer.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Haier HTQ21JAAWW Top Freezer Refrigerator
My fridge is not cooling, its running but not cooling, could you please help. Thanks Reema
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout in solving the problem.....
Aug 15, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Water on floor coming from fridge
i would call a plumber
it may be a big issue
May 26, 2009 | Haier HTQ21JAAWW Top Freezer Refrigerator
Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Apr 02, 2008 | Haier HTQ21JAAWW Top Freezer Refrigerator
Fridge won't cool
most likely its a defective thermostat,if your freezer is still working.Check to see if there is any ice build up.
Apr 12, 2007 | Haier HTQ21JAAWW Top Freezer Refrigerator
Haier HTQ21JAAWW Top Freezer Refrigerator Logo
312 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
