Vermeer baler 605 f chain diagram. came off. - Computers & Internet
  • 1 more comment
  • dealerdave1 Oct 13, 2010
    vermeer round baler 605 f . main chain came off . need diagram to replace chain. thanks david please asap
  • dealerdave1 Oct 14, 2010
    vermeer round baler 605 f . hay baler . need chain diagram
    i do not have a manual. its not easy to find . plus i needed it yesterday. now its to late.
    President:
  • 4,070 Answers
Hi! Please click on the link I provided for this may help. Have a good one and thank you for using FixYa! Please click here http://www.docsbay.com/doc/vermeer-605f-review/
Posted on Oct 14, 2010
  • 3,247 Answers
I am unsure of the problem you have with the baler. If you need the chain diagram it might be useful to purchase a service manual.
You should be able to find some details about the baler at this site.
You could try to find the closest dealer and ask for the diagram. The dealor locator is at this site.
If this does not help then please post a comment with the actual nature of the problem you want us to solve. If the information above is helpful then please rate the solution.
    Top Expert:
  • Computers & ... Master
  • 78,267 Answers
What is a baler?
    Genius:
  • 1,478 Answers
The problem posted is not clear enough, i will advice you give more details on the problem, in other to provide a solution.
Posted on Oct 13, 2010
What is the length of a Vermeer 504 super I hay baler belt?
use a piece of rope which is the same diameter as the belt, route the rope through the pulleys then put a mark on it then measure the length of the rope
Sep 22, 2017 | Super Garden
Ineed a diagram of the belt routing for a vermeer round baler 605j
as this is a specialised machine , you may have to contact the manufacturer on line where you may get a pdf version or talk with a service agent as he may have a diagram that he can e-mail or mail to you.
Aug 08, 2015 | Tools & Hardware - Others
Vermeer 252 wiring diagram
I need a wiring schematics for a 352 Vermeer stump grinder
Jan 14, 2013 | Vermeer 2006 Sc252 Stump Grinder
The shear pins on the rake keep breaking on a 853 NEW HOLLAND ROUND BALER. What is ?
Do you mean the driveline protection shear pin (pickup, roll the bale and wrap it) or the overfill protection shear pin?
For the driveline shear pin, check the type of pickup that you have. Make sure that you have the correct shear pin for the pickup (wide or regular). Also check the year of your baler, there are substitute shear bolts available that do not work on a range of the 853 baler. New Holland has a parts list for the baler on their site. Start at http://partstore.agriculture.newholland.com/us/ and use the Look up parts by equipment on the left of the page or see your manual. Next check the air bag pressure. (Make sure that you are in the operating range with a regular pressure gauge. It's possible for the gauge on the baler to read low.) If the pressure is out of the operating range, the roller bars can hit other parts of the baler and cause the shear pin to break.
If your baler uses net wrap, make sure that the wrap isn't caught in the unit. (If the knife doesn't cut the net wrap, it will get caught in the tailgate and the rest of the baler. If it tears in use, it may wrap around the pickup and cause the shear pin to break.) This may apply to twine as well but I do not have experience with it happening with the twine tied 853 baler.)
For the rest of the checks, you will have to remove any bale that is in the baler. If it is large enough it may roll out even if it isn't wrapped when the tailgate is up (try driving up hill). Otherwise, you need to pull, cut or pry the bale out. Standing on the kicker can help the bale roll out if sufficient weight is added. We've found that a spare bale spear works well. Removing the hay in small sections can also work.
What is the moisture of the bale? If the bale is too wet, it will be too heavy and shear the pin before the bale chamber is full.
Next check all of the roller bars in the unit. If any are bent significantly, that one can hit another part of the baler and break the shear pin. It's possible to straighten some of the bars out depending on the damage. If the bar is S-shaped or severely bent, replace it. (Your New Holland parts store may have someone who will demonstrate the technique for bar straightening. It involves hammering the bar straight when it is securely held in a vise. If you can hold the bar safely, I've also seen a bucket on a front-loader straighten the bars.) If a rock gets past the windrow guard, the bars can get bent.
Check that the chains are centered and that none of the gears are shifted to narrow or wider paths in a spot. (There are bars that can be adjusted between two sets of gears near the top front of the baler. Loosen the four bolts and push the parts closer or pull them farther apart.) Check that none of the bearings for the apron motion are frozen or damaged. Replace or repair anything that is damaged.
Do not make the bales too large or uneven. (If you have a Bale Command unit on the baler, it is easier to control the even formation of the bale.)
For the overfill protection, make sure to reset the unit after replacing the shear pin. It can be tough to pull the trip arm fully back. Make sure that nothing is in the tailgate. If your baler has a kicker, make sure that that the two springs on the sides are undamaged and holding the kicker level.
I hope this helps.
(my 853 baler with the wide pickup uses Driveline shear pin 46520 and Overfill shear pin 46047. I'm not sure of the year of the unit. When we got shear pins with a different number, we broke 3 or 4 in a row before realizing that we'd gotten the wrong ones; they were noticably thinner than the required ones. Roller bars are what I call the bars between the chains and we've replaced/straightened many of them.)
Aug 09, 2011 | Computers & Internet
How do I change the belt on a Vermeer 1230A Chipper?
Here is a link to Vermeer, they should be able to assist you with a diagram or PDF manual.
www.vermeer.com
Feb 10, 2010 | Garden
Computers & Internet Logo
748 people viewed this question
David Payne
David Payne
