Question about HP DeskJet 810c InkJet Printer
HP 810C. Lower of three lights winking. Ink cartridges installed. Driver confirmed as O.K. Attempts at printing form queue - now deleted. Will not print. Will not clean or do any maintenance function. Ideas please!
    Scholar:
  • 89 Answers
The blinking ink light means that the printer does not recognize one of the ink cartridges. Power the printer off, pull out the power cord, wait for awhile, replug and turn the printer on. If the light no longer blinks, ok. If not, try installing another cartridge pair if you have them available - even if they are old used ones. If the ink light continues to blink with different cartridges or if you don't have any different cartridges, old or new, you have a dilemma. Do you want a new printer or do you want to continue to chase this problem. To chase this problem, get new cartridges and install them (half the price of a new printer). If that works your set, but if not you need to have your printer serviced which is doubtful that it is worthwhile doing so.
Posted on Mar 16, 2011
Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
Apr 11, 2011 | HP DeskJet 810c InkJet Printer
It will not print. Bottom flash light goes on and off.
Nov 14, 2010 | HP DeskJet 810c InkJet Printer
How do i do a head cleaning after changing ink cartdridge on a desktop 810C printer
These cleaning steps are from the 810C user manual.
1 Double-click the HP DeskJet Toolbox icon on the computer screen.
2 Click the Printer Services tab.
3 Click Clean the print cartridges and follow the directions on the screen.
I hope this helps
TMac
Jul 22, 2010 | HP DeskJet 810c InkJet Printer
I changed the black ink cartridge but the ink light keeps blinking as there was no ink and it also makes weird noises as is the cartridge try to move but can't
you may have probably gotten a fake ink for your printer, because Hp printer will never work or print not until u put in a genuine ink from Hp. Try to purchase another genuine ink and see if the problem will occur again.
Thanks
Jun 23, 2010 | HP DeskJet 810c InkJet Printer
Toner light keeps blinking
The inkjet uses ink, not toner. When the light is blinking it indicates something is wrong with one of the cartridges, such as can't find it, not installed, out of ink, improperly installed, printer has died. First thing to try is to disconnect the power (not just power off) for 5 - 10 minutes and reconnect. If that does not resolve it, inspect the cartridges and reinstall them. If you have another printer that uses the same cartridges, try the cartridge in it. if not, get another set of cartridges and install them. If none of these steps resolve the problem, chances are that the printer is the problem and is probably not worth spending additional time on it.
May 03, 2010 | HP DeskJet 810c InkJet Printer
Ink cartridge
Is the ink cartridge now unstuck? Are the cartridge ports free of any dried ink, etc. are new cartridges in place? Try turning your printer off for several minutes and then turning it back on. Let us know if this does not work.
Aug 15, 2008 | HP DeskJet 810c InkJet Printer
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
HP DeskJet 810c InkJet Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
