Question about Refrigerators
Unfortunately the fridge half of our fridge/freezer will only cool to 11-13 degrees. The freezer works to normal set temperature. I have trief changing the temperatuire setting on the fridge but this makes no difference. I have also turned it off and let it defrost - not that there was much to defrost.
    Guru:
  • 1,524 Answers
This indicates a defrost problem.
Posted on Oct 13, 2010
How do I get my fridge to cool in cold weather with buying grill covers?
That is correct, you have reached the thermostat set point. Does not matter C or F. Read the manual it will give you the limits:
The ideal refrigerator temperature is 35°F (1.6°C). You're not hugging the danger zone like you would be at 40°F (4.4°C), and you're distancing yourself sufficiently from 32°F (0°C) that you don't freeze half the stuff in your refrigerator.
Try these links:
At What Temperature Should My Refrigerator Be Set Tips from The Kitchn
What Are Normal Refrigerator and Freezer Temps eHow
What temperatures should keep my refrigerator and freezer set at
Mar 02, 2015 | Thetford Refrigerators
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fridge is freezing....
The way you've stated your problem is confusing? The temperature is the freezer should be 5 degrees F or below, preferably at 0 degrees F. The refrigerator side should be anywhere from 34 - 38 degrees F, What exactly is the problem your having, fresh food not cooling but freezer works ok?
May 07, 2012 | Westinghouse Refrigerators
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
