Question about Refrigerators
Have to replace filter about every month & half because it starts leaking is a bit expensive at 40.00 a pop
  • g_t_hornung Oct 13, 2010
    I am on rural water supply. All of my orings and orfices are clean my water filter status
    still reads good
    Genius:
  • 1,478 Answers
I will advice you get a repair person to help look into the problem, perhaps, you can try get a genuine one at either ebay.com or amazon.com.
Take care.
Posted on Oct 13, 2010
    Guru:
  • 773 Answers
If you have well water, you might have a lot of sediment. That will cause the O-rings not to seat correctly.
Try cleaning where the water filter connections are. Use vinegar soap and water mix. That will break down lime scale and other sediments quickly.
  • Don Reiman Oct 14, 2010
    Then your cartridge socket could damaged. It may need replacing. When you take the cartridge out when it is leaking, inspect the O-rings on the filter. Look for cuts or chunks missing.
    If the O-rings are okay then check your water pressure regulator. It should be where the water main comes in the house. It may be set too high of pressure. If this is the case it is bad for more then just your fridge filter. It can damage other plumbing in your home. Over time, over pressure can deform the o-rings. If this is not corrected, it may do permanent damage to the filter socket.
    As far as being on rural water. You may still have sediment in the water. Town water only requires to be under a specific level, not free of sediment. The only way to really tell if there is sediment build up is to let the parts dry out. You will see a white film develop. But it is more likely that either your water filter socket is damaged in which case replacement parts are available, and or your water pressure into your house is too high.
    Water pressure should be 60 psi or under.
What services does Kia Sportage 2008 with 90000 need?
Here is recommended maintenance up to 10 1/2 yrs. If you follow through list, you should be able to tell by elimination what you may need. Here is the link - also list pasted below, here:
http://www.kia-forums.com/2g-2006-2010-rio-rio5/35574-maintenance-schedule.html
SUGGESTED Maintenance Schedule:
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
Jul 16, 2014 | Kia Sportage Cars & Trucks
1996 Ford F150: Running rough with knock/pop sound from lower drivers side.
Hello B Proctor,
Your catalytic converter has collapsed into itself... else check if you have a separate muffler there...
Check your on-line prices a rockauto...
Then take it to the muffler shop... or get that penetrating oil & get started...
Carnac the Magnificent
Mar 13, 2017 | 1996 Ford F150 Regular Cab
Power steering leak on 2003 CHEVY impala V6 3.8
When a power steering pump begins to fail, it's best to replace the pump and both pressure and return hoses to this system.
Recommend you replace this as soon as possible because it could eventually cause damage to your steering rack and pinion.
Jun 23, 2017 | Chevrolet Impala Cars & Trucks
Truck hesitates & stalls
Check for leaking valve cover gaskets,next to the spark plugs, putting oil near the ign coils. You absolutely have to scan the veh for codes and look at all the sensor values etc. Including putting an oscilloscope on all sensors. The Throttle Position Sensor is a possible and I could go on. Now,do not throw parts at it. Never replace anything just because of a code that is set. Codes do not mean a bad part, just an out of range sensor etc over a number of drive cycles. You have to spend lots of time and if you do not have the up to date knowledge on todays veh systems your done before you start. Don't mean to be hurtful but very few people can solve these issues including half the auto repair industry because there is no training for the most part and no one understands basic electricity or electronics. Todays vehicle are not just mechanical alone as back in the 1960's
Feb 06, 2010 | 2003 Ford Expedition
How do I tune up my 2004 GA?? It has 40,000 miles... what all needs to be changed/checked?
You need to go to a dealer or a certified mechanic. If you don't know already. Usually these will be the things you have to purchase, plugs, wires, air filter, fuel filter, oil filter & oil, you will need to flush the radiator and the transmission.
Dec 15, 2009 | 2004 Pontiac Grand Am
I have a 97 gmc sierra w/ 5.7 l engine that won't start
replace fuel filter.check fuel pressure.
Jul 18, 2009 | 1997 GMC Sierra
Missfire # 4 cyl code
are you still using the original fuel filter since the car was new?
replace it and see if that helps.
does this engine have one ignition coil for the engine or does it have one for each cylinder? if #4 is bad replace that one. good luck
Feb 23, 2009 | 1997 Buick LeSabre
Hesitation in the acceleration ,and occasional miss in idle ,park & drive
Check the resistance of the coil for number 4 cylinder....Also check compression...
Sep 19, 2008 | 2002 Kia Sportage
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
