Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Hi,how do i remove the cover of the maxicosi cabriofix infant car seat please,to wash?
  • 3 Answers
Just need to work your way round it. it's fastened in places by loops on the cover and hooks on the seat plastic, all quite stable, just go easy and see where it's fixed and how. big tip is you need the handle in an upright position. I just took mine off tonight and it took about 10-15 minutes but got there in the end.
The hardest part to figure was getting the central bottom strap through the cover - at first glance it appeared to be stuck.but if you have the seat facing you and just underneath at the front, the belt finishes, and at the end of the belt it is looped over two 'prongy' things in the seat so you just need to work that from side to side to slip it off, and you can then thread it through the hole in the seat cover.
Posted on Oct 19, 2010
I really need to take the straps off our maxicosi cabriofix car seat, taking the cover off has never been a problem but i cant work out how to remove the shoulderstraps
Hi Emily - You should never remove the harness from the carseat due to the safety implications of the harness being incorrectly refitted. To wash the harness straps please remove the fabric only and wash the harness in situ using a warm water solution with lemon juice and bicarbonate of soda to clean it up .
Feb 12, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Ive got a maxi cosi cabrio fix - i washed the headhugger/bottom support cushion that comes out (for when they are tiny) and the material has torn and the foam inner has come out - can i get a replacement...
It is normal for the headhugger to be attached to a peice of fabric lower down that contains the newborn foam cushion, this fabric is usually open so that the foam can be removed for washing.
If you want to purchase a new part, contact the link below, who will be able to assist.
http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en
I hope this helps.
Nov 02, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
I've removed the maxi cosi cabriofix cover to wash it and misplaced the round grey button that adjusts the shoulder straps can i replace this
Yes you can, this is called a Quick Adjuster I think and costs very little.
Contact www.maxi-cosi.com who will advise you.
I hope this helps.
Jun 28, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
How do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
May 15, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi cabriofix infant car seat
If you follow the link at the bottom it will take you to the cabriofix insruction manual on the maxi cosi website. (Their uk website can be found at www.maxi-cosi.com/maxicosi/default.aspx)
Link...
http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/CabrioFix.pdf
Good luck,
T
Jan 22, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Jan 08, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
901 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
