posted by NubiraOne on Jun 01, 2008
I have a Daewoo Nubira 2001 car. In the winter, the doors freeze if they are locked. I can't open then. If they are not locked, they can't be closed. This happens when the temperature is cold (even at the end of Autumn). There is no problem if the temperature is warm. Any help please?
Comment by NubiraOne, posted on Jun 02, 2008
Thanks ilragatzzo78 for replying. I tried wd40 last winter. It helped only if the temperature is not too cold. Once the temperature is really cold, the problem is back.
Best Solution
posted on Jun 01, 2008
try spraying wd40 or similar into the laches, " the ones that lock the door, looks like you ran out of grease and that's why they get stuck, little lubricant " oil " will keep moisture away preventing it from freezing again
Comment by ilragatzzo78, posted on Jun 02, 2008
then try using grease in spray, there is a silicon grease that you spray on and will get thicker.
you should find it at any part store
Rating Locked! (?) NubiraOne has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for 2001 Daewoo Nubira
Email this problem
Email this problem
Can you Help with these Cars problems?
Repair Service
Find Car Repairman Near You:
