Question about Panasonic Matshita- | UJ-845-B | USB 2.0 | DVD-+RWRAMDL (GPUJ845BU) Burner
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • Serban Soreanu Oct 15, 2010
    I have Windows XP Home.
    Please, help me!
    Thanks!
    Prof. dr. Serban SOREANU
  • Serban Soreanu Oct 18, 2010
    oui! MERCI!
  • 3,530 Answers
There are ways to fix this problem.
Method One: Remove the registry entry
Please Note: If you had installed multiple CD-writing software products on your computer, you need to uninstall the software products before you remove the registry keys.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
Note: If this data type is missing, go to Method 2.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
Method 2: Replace the existing driver
1. Click Start, and then click Control Panel.
2. If Control Panel is in Category view, click Performance and Maintenance, and then click System.
If Control Panel is in Classic view, double-click System.
3. On the Hardware tab, click Device Manager.
4. Click the drive with the question mark (?) next to it.
5. On the Action menu, click Uninstall. When you are prompted to confirm the removal, click OK.
6. Repeat steps 4 through 5 for any other drives with question marks.
7. On the Action Menu, click Scan for hardware changes.
Close all windows and reboot the computer.
Posted on Oct 15, 2010
  • Panasonic Master
  • 4,737 Answers
First uninstall the Device's Driver from Device Manager, restart your computer and again open the Device Manager and manually scan for New Hardwares with the Found New hardware Wizard.
To access the Device Manager, right click "My Computer" select "Manage" then "Device manager". This error has several fixes and it depends on the operating system (windows versions).
If you have problem or if the problem persists, let me know with more details, like the Operating System installed on your computer...
Thanks..
Good luck.
Thanks for using FixYa.
Posted on Oct 13, 2010
MY tsst cORP cdw/dvd ts-h492a QUIT reading cd's. Got erroe code 41. Need help!!!!! Unable to locate Driver.
Code 41 = Windows successfully loaded the device driver for this hardware but cannot find the hardware device.
Your optical unit has died, replace it.
Jul 14, 2010 | Compaq Computers & Internet
DVD/CD Rom Drive - Cannot find hardware devide
i think you have the motherboard to rom drive cable problem, plz change your cable and try again....
Nov 11, 2009 | E-Machines eMachines Desktop PC
Sony Walkman NWZX1060B X - hardware device not found
Just open Device manager and click the walkman device that has the code 41 then uninstall the driver. . . then reconnect the walkman it will install back and able to access again . I tried it once and it works
Nov 09, 2009 | Sony Audio Players & Recorders
Code 41 Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Which type of hardware you loaded the driver? If its WLAN or Bluetooth, then check function button for wlan and bluetooth is power ON. Or you are not loading proper driver or your hardware is not available.
Regards;
Hasan
Nov 08, 2009 | Gateway MX7525 Notebook PC / Notebook Case...
I have a dvd writer model LG GSA-E60L an when i install windows xp tells me that it is not digtally signed and also it comes up with error41 cant find hardware wont let me install and also i cant find my...
Code 41
Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Jul 08, 2008 | Computers & Internet
HELP ME
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Let me know how this works.
-Tha Mp3 Doctor
Jun 17, 2008 | Insignia Pilot MP3 Player
Laptop wont recognise dvd drive
Here is the explanation and solution for the error code 41:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
Good luck.
Apr 07, 2008 | Computers & Internet
Redgroove digital mp3 player voice recorder
PC does not recognize player - sure you used the right driver?
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)Recommended resolution
Feb 12, 2008 | iRiver iFP-895 MP3 Player
Computers & Internet Logo
174 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
