Question about Goodman Heating & Cooling
Turn breaker on to furnace and the exhuast fon comes and ac will not come on
  • 828 Answers
There should be two separate breakers for the cooling system. The furnace breaker you turned on. Now there should be a double breaker in the power panel labeled A/C or Air Conditioner. In addition there should be a disconnect at or near the outside unit. Make sure it is in the on position also. Set the thermostat to cool and the outside unit should start and run.
Posted on Jun 02, 2008
AC unit does not kick in, NO hum from motor, blower on furnace comes on, Capacitor looks good, any other ideas? Could I have a bad motor?
There is a relay in the outside unit that is controlled by the furnace. You need to check that voltage is coming to it from the furnace. If it is then you need to change the relay. High voltage is present in the unit. Turn of the breaker before doing this
Jun 08, 2015 | Heating & Cooling
Nordyne model FEH-017HA-04 furnace...the fan comes on full force with ac but not when furnace comes on
On newer furnaces the fan starts in a period of time factory set and is initiated by the control board. The air conditioning fan is started by the thermostat and starts right away when the stat calls for cooling. You will need a tech. familiar with this model and carrying the right parts to look it over. Does the furnace fire and then shut off in a few minutes? If so, it is most likely to be the board. Sorry. It may be pricy.
Oct 24, 2013 | Electric Circuit Breaker Kit for Furnace
My air conditioner won't turn on. I have flipped the breaker, I have changed the thermostat batteries, have checked the filter and it is clean, have tested the furnace but still can't find the problem
Turn your fan from auto to on, your fan should run. If it does not turn on you have a 24volt problem.
Go down to furnace and remove thermostat wires at control board. Install a jumper between R and G. Put door back on and turn furnace on. If fan comes on you have a wiring or control issue, If fan does not come on iot is possible that a little 3amp fuse located on the board is blown or your tansformer is bad.
Remove jumper bewteen R and G and put it between R and Y. Put door backon and turn on power. If your AC starts, you have a wiring problem.
If it does not start, did you check to make sure the breaker or fuse is not blown on the air conditioner?
Jul 06, 2010 | Heating & Cooling
Thermostat says -ac and my air condition will not work
is this a honeywell programable stat/ the ac means there is no 24v power coming to the stat from the systems transformer, check your furnace breaker or the switch on the side of the furnace
Jul 29, 2009 | Heating & Cooling
Turned AC thermostat to Cool today - AC didn't come on. The last time we used AC (March 2009) it worked fine. I can hear the AC Relay Board, inside the trailer, click when switching from Cool/Off &...
Just clicking is all your getting from ceiling assembly? No other modes work such as fan, or furnace? If that's the case, check your circuit breakers to make sure it didn't trip.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
I turned the AC off at the breaker box and now the AC won't come back on.
thermostsat is calling for a/c
switch outside is on
air handler switch is on or furnace switch
emergency switch to furnace or on the side of unit
cause if the coil is on the furnace it uses the same blower that is why i am asking
Jun 30, 2009 | Heating & Cooling
Power to AC does not stay on
Sounds like you might have more than one issue. If the breaker is tripping could be the compressor. If you have to press in the contacts to make it come on something is not sending 24 volts to the contactor. may be a bad wire that runs from the outdoor unit to the control board in the furnace.
Aug 03, 2008 | Carrier 38CKC036 Air Conditioner
Furnace problem
The problem is most likely in the control module of the roof air unit. Dometic uses the thermostat to activate and deactivate a relay in the control board of the roof ac unit whiich is just visible when you remove your air intake screen. The two blue with white stripe wires are the furnace control wires.
The furnace turns on and off by the opening and closing of relay. Most likely, the furnace control relay is stuck in the on position. On the thermostate, remove the fur wire and see if the furnace quits afrer it cycles down...it does not quit right away. With the termostat out of the loop, if the furnace does not shut down, the problem is in the control box. They are not hard to replace but you must be careful with the live wiire from the 110 ciucuit breaker. If you are not comfortable with the repair, take it to a dealer. The part number is on the assembly box. They need to know if you have the heat srip option or whatever othert options our Roof AC has. If the furnace still runs with the blue/white wires disconnected, the furnace wires are shorted somewhere between the furnace and the AC control unit.
Aug 21, 2007 | Dometic Rooftop RV Air Conditioner
Furnace will not light, but there is gas to the house
This problem will need to broken down in several steps. First, reset all the breakers that operate the furnace and ac. Turn the thermostat to on and the ac to off and see if the furnace blower starts. Get back with me.
Aug 12, 2007 | Haier HWF05XC5 Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
