Question about SuperMicro X8DA6 DP LGA1366 MAX96GB EATX 6SATA2 PCIE16 PCI Motherboard
Do you have to set the motherboard jumper settings? or are they preset
    New Friend:
  • 82 Answers
Jumper settings can usually be left alone. All jumper settings can be found in the motherboard manual found here:
Super Micro Computer Inc Products Motherboards Xeon Boards X8DA6
Posted on Apr 19, 2014
Cryptonteki
  • 97 Answers
SOURCE: jumper settings ms 6315 motherboard Problem - MSI MS-6315 Motherboard
this is the link to the site for the manual
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=275
Posted on Feb 21, 2008
melnavz
  • 1226 Answers
SOURCE: MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Posted on Feb 26, 2008
SOURCE: compaq presario 5340 motherboard jumper setting
key bord or system unit error
Posted on Jun 12, 2008
  • 320 Answers
SOURCE: jumper settings for EPoX EP-8RDA3IPro Motherboard
For any motherboard the power and the jumper settings are common. Please clock on the below link or copy and paste it in your browser. The entire pc assemble is given.
PC ASSEMBLE----
"http://images.google.co.in/imgres?imgurl=http://www.ezbuildyourowncomputer.com/BareBones1%2520010%2520FrontPanelConnectors.jpg&imgrefurl=http://www.ezbuildyourowncomputer.com/RemoveCover.htm&h=270&w=360&sz=14&hl=en&start=4&um=1&usg=__upxkxY8-vUBhZ6uEFumejvwWcxE=&tbnid=qlpCOg4zFD3zbM:&tbnh=91&tbnw=121&prev=/images%3Fq%3DMotherboard%2Bmanuals%2Bfor%2Bpower%2Bconnections%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DG"
CMOS SHORT------
"http://images.google.co.in/imgres?imgurl=http://www.pcbuyerbeware.co.uk/ClearCMOS.gif&imgrefurl=http://www.pcbuyerbeware.co.uk/ClearBIOS.htm&h=728&w=546&sz=18&hl=en&start=3&um=1&usg=__LxchryVCJTZvmufhnbWSIKWT2Ls=&tbnid=_x_3clEXoNn4oM:&tbnh=141&tbnw=106&prev=/images%3Fq%3DMotherboard%2Bmanuals%2Bfor%2Bjumper%2Bsettings%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DG"
Thank you....
Posted on Sep 11, 2008
olwork
  • 237 Answers
SOURCE: Need manual to set jumper settings for Epox
Download this.
Posted on Jul 01, 2009
My motherboard (intel DG41WV) is starting but not giving output to screen. I have cheked cables sokets. Even i have cheked to other screen. but problem is still. all peripherals (fan, cd-rom...etc) are...
Jumpers:
Motherboard installed in computer case;
A) Keyboard Jumper Block
3-pin jumper block, Top of motherboard/ left side. Near the mounting hole, and 4-pin ATX +12 Volt power cable connector,
GENERAL example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ This power cable MUST be plugged into the motherboard.
It is power for the Intel processor ]
3-pin jumper block.
Starting at the TOP coming down;
Pins 3, 2 and 1.
Jumper cap should be on Pins 2 and 3.
(Enables the Keyboard wake-up feature. Factory default setting is Enabled. Pins 2 and 3)
B) Clear CMOS Jumper Block.
BOTTOM right corner of motherboard. 3-pin jumper block.
It is to the Left of the bottom/left SATA connector.
It is immediately to the Right of the motherboard mounting hole.
Starting at the Top, and going down towards the bottom edge of the motherboard;
Pins 3, 2, and 1.
Jumper cap should be on Pins 1 and 2.
When you changed the SMPS, do you KNOW for a fact it is a good one?
Did you plug the 4-pin ATX +12 Volt power cable, into the motherboard?
What COMS setting/s did you change?
I would go back into BIOS Setup, and set that menu screen back to the factory default settings.
[ Load Optimal Defaults ]
BIOS Settings Glossary,
http://download.intel.com/support/motherboards/desktop/sb/biosglossary_v18.pdf
Regards,
joecoolvette
[Motherboard manual - http://www.intel.com/support/motherboards/desktop/dg41wv/sb/CS-031417.htm
Nov 11, 2012 | INTEL - MOTHERBOARDS Computers & Internet
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Oct 01, 2011 | Shuttle MK40VN Motherboard
What is the purpose of the diagram of jumper setting?
The jumper settings (if this is the one you are speaking about) are for clearing the BIOS (times, dates, hardware etc...). The diagram is probably showing the settings on which pins to jump when clearing.
Hope this helps.
Nov 09, 2009 | Intel D865GBF Motherboard
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Award BootBlock Bios V 1.0 copisight (c) 2000, Award software, Inc Detecting floppy drive A media Scanning Bios image in Hard Drive..... What is this? please help me.
Hi how are u, it is simple problem friend
Your motherboard jumper setting has been changed.
please read manual of your motherboard jumper setting if u not have manual. open ur pc cover and see the motherboard jumper.
remove your bios battery and change your jumpers 2-3 by defualt.
i hope u are understand u will change your motherboard jumper settings bye.......from mukesh_ibm@yahoo.com
May 13, 2009 | Gigabyte Computers & Internet
Want to disable onboard ethernet port need to know settings for jumpers on motherboard
TriGem 011027 (Lomita)
As far as I know the only jumper settings for this motherboard are very limited. The jumper settings stated on the link above are for clearing CMOS settings and Clearing Bios password.
I would suggest booting into the Bois settings to see if you can disable the on board Ethernet controller there, it should be in I/O devices settings.
Hope this helps, take care
May 05, 2009 | Intel Motherboard
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
Im looking for the jumper settings on a compaq motherboared. its a presario 7478
hello CAVdesert,
I don't think you ever have to change the jumper settings on the motherboard.You may need to change in few cases but otherwise, changing motherboard jumper settings is not recommended.
However, if you need to configure the jumper settings for your Hard Drive, CD/DVD Drive etc, Please refer to the following document.
Jumper Settings for the Installation of Hard Disks and CD, CDRW, and DVD Drives
Oct 12, 2008 | Compaq Computers & Internet
Hello!
Feb 25, 2008 | MSI 845GE Max-L (MS-6580-060) Motherboard
SuperMicro X8DA6 DP LGA1366 MAX96GB EATX 6SATA2 PCIE16 PCI Motherboard Logo
101 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
