Question about Belkin Computers & Internet
Is it possible to connect cat5 cable to phone jack - from the router to the printer
    Scholar:
  • 110 Answers
No, Cat5 and phone jacks are purposefully different sizes. They have no compatibility.
If you want to share a printer over a network and it doesn't directly have a cat5 port (most don't) your best option is to set up a basic home network using the wizard, make sure that FILE AND PRINTER SHARING is switched on, and then share the printer as a resource on the machine it's already linked to. Then as long as that machine is turned on (even if it's not doing anything) the printer will be available to other machines on the network, even if those other machines are communicating wirelessly.
Posted on Jun 02, 2008
Which wires on the Cat5 are connected to the WAN Port
Cat 5 is a cable configuration standard that uses a plug and jack that is similar to a modular phone jack called rj45. Those cables plug into multiple points on the router. If you have a separate cable modem, the cat 5 cable from the modem connects to the WAN port on the router.
Mar 08, 2016 | Computers & Internet
Do I need special knowledge to install? Does it need a hardwire from the modem or just go from the wireless router?
You will need to connect your cable modem or DSL modem via CAT5 network cable to the WAN (Wide Area Network) or "Internet" jack of the router. The LAN (Local Area Network) jacks are usually numbered sequentially starting at "1". Equipment that you connect by CAT5 cable from the routers LAN (numbered) jacks should need nothing more.
If yours is a WiFi router, you should then login to the router to access the setup pages. Locate the Wireless tab and ENABLE the Security to WPA or WPA2. Do not leave it unsecured or set to WEP. If the SSID contains the brand or model of the router, ie: Netgear, Linksys, etc. CHANGE IT to anything you want other than your name, address, password, etc. Write down and SAVE your settings. Next, locate and click on the Administration tab. Here, you should change the default PASSWORD and if possible, the USERNAME. Write down and SAVE your settings.
Finally, write these settings on a small piece of paper and tape to the underside of the router. You may want to include the IP address if you made changes. This way, you can always find out the network security credentials if you need to provide them to a guest, etc.
Feb 28, 2015 | Computers & Internet
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
Need to know what i need to connect my prewired home (with cat5 cable running from box in garage to jacks in 4 rooms) to the internet. currently just have cable modem in office.
You would need a 4 - 8 port router... with a wire going to each Jack... and these would plug into the Router ports, The router plugs into the Modem. You have to put the Ethernet plugs on each end of the Cat5 cable. Then you setup your network. But if you have a wireless router you simply need each PC WiFi enabled, IE: A wireless card in each PC, that way you do NOT need Cat5. Then each PC, simply connects to the Router/Modem.
Mar 05, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
No IP address on Brother Printer
Hi, I am assuming that it works whn it is connected directly to your system, as you told that you got your printer replaced. And as you may know that connecting through CAT5 cable is the RECOMEND way..but thats what every1 else tell. So now, the 1st doubt that comes in my mind is about the OS you are using. The model you are using is compatible with Windows, Mac & Linux.
The 2nd possibility rises have you installed the appropriate driver for the printer you are willing to use and check your wireless settings too.
Now the 3rd possibility is that maybe there is something wrong with your router. Maybe you should make sure that the router is working properly.
Nov 26, 2009 | Brother HL-2170W Laser Printer
Cat5e jack by leviton has eight slots, but my cat5 cable only has 4 wires in it. I punched the wires down on the back four connectors. As long as I do the same on my ends, this should work right? Please...
Cat5 has eight wires, anything less is for telephone. Your cabe is for telephone if it has 4 wires. Either return the cable and get 8-wire cat5 or go to another store for your cat5 wire.
Jun 10, 2009 | Leviton Quickport 5G108 Category 5e...
Is it possible to have 2 pieces routers to expand the distribution of internet connection instead of using router to hub? what type of cabling should i used to do it? please help thanks
I guess you have a single incoming internet connection and wish it to be shared.
You only require one DSL / Cable router. To share this connectivity you will need Ethernet / Cat5 or wireless.
An ethernet switch or hub will enable you to extend connectivity.
All cable should be CAT5e or CAT6.
Suggest you consider the slightly more expensive switches that have auto-uplink. The negates the need of crossover cables.
Regards B.
Mar 21, 2009 | 3Com Computers & Internet
Dont know how to hook up cat5e cable to a leviton cat5e jack
Those two jacks are telephone jacks (RJ-11) not ethernet (RJ-45). The jack marked telephone is for a phone, and the jack with a rectangle symbol is for the telephone line into the wall.
You need to buy an ethernet PCI card - without one you can not use a cat5e line (which has an RJ45 connection).
Nov 22, 2008 | Leviton Computers & Internet
Multiple router
Yes, you can use multiple router on one single internet line, in order for you to do that you need to connect the second router to the main one using a CAT5 cable/Ethernet and everything should be ok already.............
Oct 24, 2008 | Linksys WRT54G3G Wireless Router...
Computers & Internet Logo
69 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
