Question about GE GSH25JFR Side by Side Refrigerator
Ge refrigerator gsh25igrb ww ice build up all around ice maker and back wall of refrigerator. replaced water valve about a year ago... think it might be the valve again?
larryyb
  • 291 Answers
SOURCE: GE gss25ifrf ww Ice maker
you will need to replace the dispensor board part number WR55X10444
Posted on Dec 04, 2008
  • 145 Answers
SOURCE: frost build up in freezer (ice maker section)
Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
the is a easy way to adjust that but you are going to have to take
your ice maker out
then using a flat head screw driver remove the white square cover
you will see a gear and a adjustment screw and a lever like this
( - I + )
turn the screw to the minus sing a quarter way and install the ice maker back up.
Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
the ice maker feel up buy time not buy water level.
Posted on Jun 28, 2009
jmeredith
  • 417 Answers
SOURCE: Frost build up...refrigerator not cooling
hi,
your condenser fan may have gotten stopped up with ice. You can try to open the freezer door and push the door buttons while the compressor is running and you should be able to hear the fan running in the freezer compartment. If not you can try to completely defrost the machine by unplugging it and letting it sit for a day, you can speed that up by putting a hair dryer on low and point it at the cold air outlets. If it does it the next day you can pull the condenser fan. usually the whole back plate in the freezer has to come out and then the fan is right there. try spinning the blades by hand , should turn easy, you can try oiling it but it should be replaced, you can order it at the appliance store, take it with you. be careful while you have that inner cover off as the coils are sharp and fragile.
good luck
J
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Posted on Nov 18, 2009
aasc
  • 1606 Answers
SOURCE: my ge side by side model gss25jfmc ww will start
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Posted on Jan 02, 2010
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
GE TFX22ZR side by side. ice maker not making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER NOT WORKING ,MODEL #gss25lgma ww
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
Worst refrigerator I ever owned--a lemon
I won't say I can solve your problem short of coming around and loading your POS fridge in to the back of my truck and running by the scrap metal yard. Keep contacting GE and the retailer who sold it to you about your problems. Hopefully one or the other will get sick of hearing from you and give you a replacement. A 20 cubic foot over/under fridge with ice-maker can be had for $450 US, which should last you around 10 years or so, which is pretty much typical for white goods. I have had pretty good luck with Frigidaire and Hotpoint so far. I still wish I hadn't put the 40 year old Wizard Imperial 14 cubic foot bottom mounted freezer that I bought about 23 years ago out at the curb. Given the chance, it would probably still be working today, as ugly and inefficient as it was.
Jun 17, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Water spout to ice maker frozen
defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Dec 14, 2008 | GE Profile Arctica Stainless Steel Top...
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSH25JFR Side by Side Refrigerator Logo
129 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
