Question about Yard Man Mulchinator QuickShift BlowerVac Yellow
My YardMan leaf blower is losing power. I put in new gasoline but still not enough power to blow the leaves.
5 Suggested Answers
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
  • 31 Answers
SOURCE: leaf blower that wont run at high rpm
You need to replace your fuel lines.
Posted on Nov 09, 2009
SOURCE: gas leaf blower runs at half speed
I have a craftsman 2 cycle 25cc hand held leaf blower. Before storing it for the winter I ran the fuel dry. Upon refueling it and trying to start it with the choke on it will run but when I shut off the choke or move the throtle to the run setting the motor stalls.I believe that the problem maybe related to the carberator and would like to clean it.Could you possibly instruct me as to how remove and clean the carberator on a small 2 cycle motor like this. Thank you Joe Gulick
Posted on Jun 02, 2011
  • 4 Answers
SOURCE: YardMan 290 leaf Blower seems to have no spark. I have changed the plug and it still has no apparent spark. Is it possilbe the coil is bad or magnets need cleaning?
Check the fuel lines.
Posted on Sep 26, 2012
How do you clean air filter of poulan leaf blower?
You can use Gasoline or Varsol. Blow dry and you should lightly oil the filter again before installing it.
Jan 24, 2015 | Poulan Garden
Poulan 2000 leaf blower shuts down after getting hot (7-10min)
Make sure your oil to fuel ratio is correct. You cannot run it on gasoline alone.
Oct 20, 2014 | Garden
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Blower works for a while then begins to lose power and eventually turns off and won't turn back on. Has a full tank of same mix I've been using for years. what is the problem?
I'd check the fuel filter in the tank 1st. There is enough line to pull it out and off and you should be able to blow thru it. The I'd check compression which should be 90lbs. or above and if that's OK I'd pull the muffler to make sure it's not clogged up. I'd probably also disassemble the carb & blow air or carb cleaner thru it. Good Luck
Sep 01, 2010 | Ryobi Backpack Blower 25.4cc
Homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
Dec 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Husqvarna 125bt backpack leaf blower. I put
Oct 21, 2009 | Husqvarna Forest & Garden 125bt Backpack...
I have a yardman riding mower. It has gasoline mixing with the oil. Can this be repaired.
Yes. Mostly likely is that your rings on the piston head are radically worn out. One thing to do is to take off the cylinder head and check the rings and replace if needed.
Aug 10, 2009 | Garden
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Yard Man Mulchinator QuickShift BlowerVac Yellow Logo
186 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
