Question about Dryers
Maytag Neptune Model MDG3000AWA , not heating drying and the vent is not pluged? !0 years old
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad, dont think it is the heating element. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 13, 2010
Hi I have a Maytag Neptune gas dryer model mdg3000awa.
i need more info about your maytag neptune dryer is there any issues you are facing with this dryer model?
Feb 22, 2017 | Maytag Dryers
My maytag neptune isnt drying the clothes after they have been in for an hour?? my husband and i have always taken good care of the set, its like 4 or 5 years old. does a part need to be replaced an if so...
Check the inside vent duct on the machine and also the external duct all the way to the outside wall. I'm sure you will find lint buildup that is hampering the dry cycle.
Jan 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is 5 years old and does not seem "heat"
werrw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. If the problem does not inprove, you may have a defective heat coils
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have Maytag Neptune dryer. It is not heating when drying the clothes. It is about 10 years old
the most common problem if its electric is the heating element the secound most common problem is the fusable link if the fuse link to the relay has not blown then replace the heating coil
Sep 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Takes very long to dry
lint in the vent tube or constriction, clean and straighten out. Should solve the problem
Jul 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag SDE515DAYW
could be a bad thermostat or power control board.
also make sure you getting the corret voltage otput at the wall socket using multimeter
Jan 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
152 people viewed this question
Top Dryers Experts
