Question about Nokia E52 Smartphone
My nokia e52 appears offline mode and switches itself off and asks me to restart it many times aday
zaids
  • 456 Answers
SOURCE: Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Posted on Jan 14, 2009
SOURCE: Changed nokia e66 housing.. and now offline
I have the same problem..i replaced the sim band and the problem still persist.. what to do ? :' and my wifi dont detect any network :' wtf?:((
Posted on Oct 15, 2010
  • 14 Answers
SOURCE: I bought a Nokia E52 when ever i use it offline
Best bet with Nokia is have the dealer/seller reset for you; they have direct connections with their manufacturer site, & have every possible cable/download; it is a bit of a pain to do, but taking the time to do it this way will save you sooooo much trouble, as Nokia phones can be very tricky. When they do a direct-dock, all your data is saved (phone #s & other contact info, ect). Bonus to this is they may possibly do some up-grade on your software, because it sounds as if your phone & any WiFi you come close to are causing interferance with your cell.
Best of luck, hope the dealer gets to you as soon as you walk in (try booking an appt for issue, this often works quite well & they appreciate the heads-up so they can be more prepared), hope you have a lovely holiday season.
Posted on Nov 17, 2010
SmokinJoe666
  • 77 Answers
SOURCE: My Nokia E52 is currently
Press the power button (On the top of the phone) just once and you will get options to Switch Off , Change the profile etc. In that you will get the Online mode. Hope this helps. Good Luck ~SmokinJoe~
Posted on Apr 26, 2011
Camera not working
hi, i hv nokia e52. after *#7370#, phone is offline mode.
Jan 04, 2014 | Nokia E52 Smartphone
Hi i have nokia n72 phone. its only working in offline, if i change the profile its showing insert sim card, so pls help me
Hi, kindly switch off the mobile and restart it, once you restart this will ask u phone is currently offlline mode u want to countniue, that time click no, phone will start.
May 31, 2011 | Nokia N72 Cellular Phone
My Nokia E52 is currently offline. How do I get it back online.
Apr 26, 2011 | Nokia E52 Smartphone
Nokia E52 stays in offline mode after swapping sim card
It stays offline if the card is not allowed by your service provider or it is not contacted well.
You can try to clean the metal pins, if it causes a contact problem.
Apr 11, 2011 | Nokia E52 Smartphone
My E52 has gone into Offline. How can I change this
OFFLINE mode is just like a profile, try to select a different profile from settings.
CHEERS!
How to deactivate offlinemode of my nokia e52
To switch OFFLINE mode on/off:
  1. Press Menu (left soft key)
  2. Highlight Ctrl. panel and Open (Navigation key)
  3. Highlight Profiles and Open (Navigation key)
  4. Select a Profile of your choice and then press in Navigation key
Alternatively,
  1. Press the on/off button quickly and the list of Profiles will be shown
  2. Select a Profile of your choice (Navigation key)
Hope this helps. If so, kindly vote.
-regards,
Mrigs
Mar 04, 2011 | Nokia E52 Smartphone
How to remove offline mode in nokia e72 mobile
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
Feb 26, 2011 | Nokia E72 Smartphone
My unit is Nokia E52.please help me how to deactivate power saving mode because i can't change my light time-out due to power saving mode active.
As Nokia E52 is the ESSENTIAL MODEL Mobiles, As its in high Range of Applications Used to get it's Visual.
Here are the Fiew tips to DEACTIVATE the Power Saving Mode.
1. First Switch on your Mobile.
2. After completing it's Process, Click the Menu Button.
3. Go to the Settings
4. Settings -> Display Settings
5. Go to the Power Saver Mode Option,
6. Change the Mode of Operation from ON to OFF
7. As Now go to the Screensaver Settings,
Change the Time-Out time to your Favour.(Not Less than 15 Secs)
7. As after this setting is Done, Restart you Mobile Phone
But Kindly Connect your Phone with Nokia PC Suit and Update your Phone to keep your phone upto date of the Latest firmware.
To get the Updater, Click the Link Below
http://www.nokia.com.sg/support/download-software/phone-software-update
Click the Download Button in Update using your PC section, There you can find Nokia Software Updater, Select your Language.
Jan 03, 2011 | Nokia E52 Smartphone
My nokia E5 is in offline mode, how do i switch it to online?
Offline mode is usually caused because the SIM card is not accepted by service provider or SIM card has bad metal contact.
go to settings, and profiles...
then change it to general mode, or loud mode.
Oct 27, 2010 | Nokia E52 Smartphone
Nokia E52 Smartphone Logo
487 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
