Question about IDEAL Vol-Con Xl Voltage/Continuity Tester
I just purchased a Vol-Test XL and can't figure out how to install new batteries. Can you help?
    Master:
  • 683 Answers
Posted on Oct 31, 2013
2 Suggested Answers
  • 3289 Answers
SOURCE: What does it mean when I test and get a clear signal and then it fades to nothing?
Hi -
First, make sure the battery in the tester is good. If unsure of the batteries charge state, replace them (requires {4} IDEAL# 61-201,
IEC #LR44, or NEOA# 1166A) before continuing.
What you're describing sounds an awful lot like a testing of a capacitor. If you were to connect an analog ohm meter to a capacitor, the needle would indicate a very low resistance value and gradually swing to a very high resistance value. it would not take more than a few seconds to go from low to high indication. Use of a digital meter wouldn't show this very well, as the resistance value is constantly changing - rendering an actual numeric value impossible to display.
Once the resistance value has reached the high value on the meter, swap the polarity of the leads, and it should read low again - and climb to the high value once more. This will happen each time the leads are reversed.
You can view the manual here.
I hope this helps & good luck!
Posted on Apr 24, 2012
The presser foot on the brother xl-5130 has fallen off
please send me a picture and I will gladly assist you with all the help you may need ;)
Nov 20, 2013 | Brother XL-5130 Mechanical Sewing Machine
Just had new battery installed on my 2006 Road King. batter tender stays yellow.
Hi Anonymous, you could have bought a bad battery that's why they have warranties, have a load test performed on the battery. Good luck
Aug 26, 2013 | 2006 Harley Davidson XL 1200 C Sportster...
Hi -
Apr 04, 2012 | IDEAL Vol-Con Xl Voltage/Continuity Tester
How do u change the batteries On a vole-test xl
there is a small clip at the back push both side in at ounce and the back will come away
best of luck
merry christmas
Dec 07, 2010 | IDEAL Vol-Con Xl Voltage/Continuity Tester
Hello, have a 2003 XL 1200 custom that wont start,what is happening when you kick it over and it starts clickin then starts to die away like battery going dead. cheers Jes
I think you hit the nail on the head, Jes. Sounds exactly like your battery is going dead. Just to make sure, take the battery out of your bike and take it to an automotive parts store. Have them test the battery. They'll usually do this free of charge. If your battery is over two years old, it's probably bad.
Now, if you purchase a new battery, get the highest CCA (cold cranking amps) battery you can get. Also, consider the purchase of a Battery Tender or a Smart Charger that will connect directly to your battery via a short pigtail. Do not use a regular automotive battery charger. Put the pigtail on your battery and when you get of the bike, plug the charger to the battery. This will increase your battery life tremendously.
Good Luck
Steve
Sep 12, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
2004 Suzuki XL-7 wont start
to sachah359: were able to figure out what the problem was with your XL-7 not starting? I'm having the same problem.
Sep 22, 2009 | 2004 Suzuki XL-7
Unable to download map onto tomtom one xl
If you have an older tt xl it will only take up to a 2gb sd card. Larger than that you will get errors.
Hope this helps
May 30, 2009 | Tomtom ONE GPS Receiver
Voltmeter trips GFCI
I think this is normal for a GFCI.
May 01, 2009 | IDEAL 61-086 Vol-Con XL Solenoid Voltage...
IDEAL Vol-Con Xl Voltage/Continuity Tester Logo
255 people viewed this question
Top IDEAL Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an IDEAL Measuring Tool and Sensor Expert? Answer questions, earn points and help others
