Question about Grilling
My char-broil performance series model# 463453206 grill is having trouble getting a large flame. All burners will ignite with fire coming from all of the little holes on the burners but the flames seem very small, i was thinking it may be due to the burners being dirty. If this is so, how do i go about cleaning them and what would i use to do so??
SOURCE: Low gas flame
Also read the manual, You must open the LP tank valve very slow, the new tanks have funny safety design, I had low flame on the 2nd use w/full tank and was puzzled because it was high flame on the night before.
Rizzo
Posted on Jul 24, 2008
Iceboxman
  • 18 Answers
SOURCE: low flame
Bad pressure regulator.
Posted on Sep 10, 2008
SOURCE: Char-Broil TEC Infrared Grill the
what do we do about the sputtering tec gas line and no heat on tec burner
Posted on Feb 23, 2009
  • 784 Answers
SOURCE: SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP
The regulator is damaged. This is the little round between the hose connected to your knob adjustment and the Gas tank. This one is not expensive. it costs less than 30 bucks. Good Luck.
Posted on Jul 06, 2009
97F350diesel
  • 1326 Answers
SOURCE: My Char Broil gas grills flame is taller than it
You need to clean the burners/pathways, its not getting enough oxygen and the flame is starved.
Posted on Sep 05, 2009
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
First burner ignites quickly, second and third take up to 3 minutes IF they fire at all. burners are not clogged.
If the first burner's flame characteristic's look right, the remaining burners need to be removed and the venturi valves and burner orifices checked for obstructions and cleaned if necessary.That's generally the cause of delay ignition.
Hope this helped and Happy Grilling!
Mar 20, 2011 | Char-Broil CharBroil Master Flame Gas...
Will not produce high flame properly
You probably have a bad regulator which you can buy at most stores that sell BBQ's.
Apr 07, 2010 | Char-Broil Performance 463463006
Does the char-broil performance have shields over the burners
yes all grills do so it will not flame up and burn the food!
Apr 02, 2010 | Char-Broil Performance 463463006
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP WAS 600,TURNED OFF IMM.SINCE THEN GRILL LIGHTS,FLAME IS VERY LOW OTHER BURNERS LIGHT BUT FLAMEIS LOW. HAVE CHECKED GAS SUPPLY.EVEN PUT ON A NEW TANK.SAME...
Jul 06, 2009 | Grilling
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
http://www.charbroil.com/
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Apr 19, 2009 | Char-Broil Advantage 463453306
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Grilling Logo
184 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
