Question about Breezaire WKL 4000 Wine Cooler
My breezaire 4000 runs all the time. Any help would be greatly appreciated. Thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
CONTACT THE MANUFACTURER 858-566-7473 , ASK FOR A TEMPERATURE DIFERENTIAL TEST , THEY WILL EMAIL IT TO YOU AND THAT WILL HELP THEM DETERMINE IF THERE IS A FREON LEAK OR IF SMOETHING ELSE IS GOING ON
Posted on Sep 16, 2011
Wont run. It blinks
YOUR UNIT WKL 4000 CONTROL BOARD HAS THE FOLLOWING FEATURE ON START UP UNIT WILL RUN FOR 30 MINUTES IF IT DOENST BRING THE TEMPERATURE IN THE CELLAR BELOW 70DEGREES IN THAT TIME IT WILL SHUT OFF AND DISPLAY E1, YOU NEED TO UNPLUG UNIT FOR 15 MINUTES(NO LESS THAN THAT) AND THEN PLUG IN AGAIN IT WILL RUN AGAIN FOR ANOTHER 30 MINUTES ABD IF IT DOESNT BRING THE TEMPERATURE BELOW 70 IT WILL SHUT OFF AGAIN.YOU WILL HAVE TO REPEAT THIS CYCLE TILL IT GOES BELOW 70DEGREES (MOST CUSTOMERS WILL HAVE TO DO THIS CYCLE TWICE).ONCE THE UNIT BRINGS THE TEMPERATURE BELOW 70 IT WILL RUN NON STOP TILL IT MEET THE SET COOL POINT.IF YOU REPEAT THIS STEP SEVERAL TIMES AND THE UNIT NEVER BRING THE TEMP BELOW 70 DEGREES THERE HAS TO BE SOMETHING ELSE GOING ON, LIKE A REFRIGERANT LEAK.CHECK THIS LINK FOR THE INSTRUCTIONS THAT EXPLAIN THE FEATURE I TALKED ABOUT AND OTHERS ON THE CONTROL LER OF YOUR UNIT(SENTRY III)http://www.breezaire.com/downloads/sentrymanual.PDF
Sep 15, 2012 | Breezaire WKL 4000 Wine Cooler
I have a WK 4000 with the condensation drip line that keeps popping out. What is the best way to fix this permanently?
YOU CAN BUY A NEW DRAIN HOSE FOIR LIKE $15 TO $20 WITH A NEW NIPPLE ON IT AND DO ALL PREVIOUS STEPS EXPLAINED TO UNCLUGG THE HOSE.
Sep 02, 2012 | Breezaire WK 4000 Wine Cooler
This unit is 15 years old and the drain tube was never hooked up believe it or not and it leaked terribly with now a rusted out bottom. The unit works however and I was wanting to fix it. Can a new...
IF YOUR UIT IS IN FACT 15 YEARS OLD IT CAN NOT BE A WKL MODEL, WKL ARE DIGITAL UNITS, WHAT YOU HAVE IS A WK4000 WITH A SCREW TEMPERATURE ADJUSTMENT IN BETWEEN THE GRILLS.
A 15 YEAR OLD WK 4000 IS AN R-22 SYSTEM AND NOT WORTH REPAIRING AND IF THE METAL IS RUSTED YOU CAN NOT BUY MORE METAL BASES FOR THAT UNIT FROM THE MANUFACTURER, BREEZAIRE HAS DROPPED ALMOST ALL THE COMPONENTS FOR THE UNIT ONLY THINGS AVAILABLE ARE FANS,COILS AND THERMOSTAT.
BUY THE REPLACEMENT WKL4000 DIGITAL SAME DIMENSIONS AND COOLING CAPACITY.
http://www.breezaire.com/wp-content/uploads/2011/04/WKL-Insrructions-3-11.pdf.pdf
CHECK THE LINK FOR THE INSTRUCTIONS ON THE NEW WKL UNITS
Sep 19, 2011 | Breezaire WKL 4000 Wine Cooler
WK4000 breezaire 60260229 need exhaust fan motor ser.34T U mod.JA2M430N 6CV79C
PART IS SOLD AS TWO SEPARATE COMPONENTS MOTOR AND BLACK PLASTIC BLADE APROX $80 FOR BOTH
Jul 23, 2011 | Breezaire WKL 4000 Wine Cooler
WKE 3000 temperature panel has stopped working - unit still turns on and off properly.
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
Nov 11, 2010 | Breezaire WKL 4000 Wine Cooler
Unit runs but does not cool.
IF YOU UNIT IS IN FACT A WKL UNIT(DIGITAL DISPLAY) IT COILD BE TWO THING A BAD BOARD THAT IS NOT SENDING POWER TO THE COMPRESSOR OR A FREON LEAK.
ON MAJORITY OF CASES ON A FREON LEAK THE UNIT WILL FORM ICE ON THE COIL, SOME TIMES A LOT OF CONDENSATION ON THE BODY OF THE UNIT AND IT WOULD LOOSE COOLING GRADUALLY UNITIL IT WOULD RUN NON STOP.
CONTAVTTHE MANUFACTURER FOR A BOARD OR ASK FOR A TEMPERATURE DIFERENTIAL TEST TO CHECK FOR A FREON LEAK.
Oct 25, 2010 | Breezaire WKL 4000 Wine Cooler
The unit is a Breezeaire wine cooler. The evaperator is freezing up.
MOST LIKELY A FREON LEAK ALMOST 90% OF UNITS WITH FREON LEAKS DEVELOP ICE BUILD UP ON THE FRONT COIL, AND AFTER A PERIOD OF TIME IT GOES AWAY AND THEN UNIT RUNS NON STOP GETTING WARMER AND WARMER TILL IT HITS ARROWND 70 T0 72 DEGREES.
Oct 02, 2010 | Breezaire WKL 4000 Wine Cooler
I have the 8000 WKL Breezaire it has started to frost up over and over. I turn it off to melt and it starts to frost as soon as it starts to cool the wine room. Why?
IF THE BLOWER ON THE COLD SIDE IS NOT RUNNING THAT WOULD BE THE REASON WHY THE COIL FREEZES UP AND IT COULD BE DUE TO A BAD BLOWER CAPACITOR LOCATED ON THE BACK OF THE UNIT LEFT SIDE (SMALLEST OF THE TWO OVAL CANISTERS), BUT IF THE BLOWER IS RUNNING ON THE COLD SIDE IT MOST LIKELYIS A FREON LEAK, AND UNIT NEEDS TO BE RECHARGED WITH FREON AFTER REPAIRING THE LEAK.
Sep 27, 2010 | Breezaire WKL 4000 Wine Cooler
Unit runs gets only to 62 degrees. Top exhaust clean. 5 yrs old
CONTACT THE MANUFACTURER BREEZAIRE 858-566-7473 THEY WILL CONECT YOU WITH A DEALER THAT STILL MODIFIES UNIT TOP VENT.
BREEZAIRE DOES NOT MODIFY THE UNIT TOP VENT THEM SELF NOR DO THEY SELL DIRECT BUT THEY WILL PUT YOU IN CONTACT WITH THEIR DEALER THAT DOES.
Jun 06, 2010 | Breezaire WKCE 2200 Wine Cooler
Inside coils are getting iced up.
One or both coils (indoor and outdoor) are dirty or plugged. Take the unit to a reputable repair shop and have it cleaned and oiled. This should be done at least once a year anyway.
It's possible that it might have a leak. The shop that cleans it can check it for you after they clean it. If this is an old unit, it probably wouldn't hurt to have that done.
Jul 08, 2009 | Breezaire WKL 4000 Wine Cooler
Breezaire WKL 4000 Wine Cooler Logo
216 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
