Question about Refrigerators
My samsung fridge/freezer has stopped making ice
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Hello it may help if you have alook at this video on samsung diy help
Posted on Oct 19, 2010
I have Samsung rfridgewith freezer on bottom. We replaced the the ice maker but but now it makes ice just won't dispense
try defrosting the ice dispenser portion of the unit, it might have ice buildup stopping the auger from functioning
Jul 13, 2017 | Samsung Refrigerators
I have a Samsung RS21DPSM American Fridge Freezer it has stopped making ice the water dispenser works fine but no water going into ice maker?
check the line that runs up the back of the fridge u have to take the back off sometimes there is something wrong w that line or there could be some water has frozen in the top of the line that goes into ur icemaker inside the freezer
Feb 28, 2015 | Samsung Refrigerators
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
My Samsung rs 2556 SH side-by-side fridge is making a loud whirring noise, but when I open the fridge the noise comes to a sputtering stop. It starts again a few seconds after being closed. Noise sounds...
there is a evaporator defrosting problem; ice building-up. the evap fan is mounted right on top of the evap coil. this will get progressively worse; and, the fan will get completely jammed with ice; and stop altogether. your fridge will get warm and the freezer will not cool properly. you should get it looked at asap..
May 18, 2010 | Samsung RS2630WW Side by Side Refrigerator
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
My fridge not cold but freezer working fine
there is a shaft from freezer to fridge that the cold air travels. make sure that is unblocked. also make sure the fan is working. then see if the freezer coils are iced up (this restricts air flow). if they are, unplug it, empty the fridge and freezer, defrost the coils, dry it out, plug it in and turn it on (not high). once it reaches the temp and the compressor stops, fill the fridge again.
Jul 30, 2009 | Samsung Refrigerators
Samsung RL33SBNS FRIDGE FREEZER LEAKING WATER
I HAVE HAD THE SAME PROBLEMS WITH THIS FRIDGE FREEZER-THE ENGINEER WHO CAME TO FIX IT SAID THAT SAMSUNG STOPPED MAKING THIS MODEL BECAUSE OF THE PROBLEMS WITH IT- THE ENGINEER REPAIRED IT BY DEFROSTING IT WITH A WALLPAPER STREAMER AND ALSO SAID HE CUT OFF A PIECE OF THE RUBBER TUBING WHICH CARRIES THE WATER THROUGH THE DRAINAGE SYSTEM BUT HE COULDN'T TELL ME WHY IT DID THIS IN THE FIRST PLACE
Mar 22, 2009 | Samsung Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Ice tray stuck
Hi My Samsung freezer was nor a RB2155 it is a RS2630SH however after not making any ice because the tray was stuck in the upside down position or thereabout after 6 weeks it suddenly started making ice again, we had not done anything to it but we heard it dropping ice one evening and we had a look in the ice container and low and behold the ice box was full to the top, I would still like to know why it went like that in the first place in case it happens again it is a mystery. Larry
Oct 09, 2006 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
