Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Power button flashes 10 times - Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
    Genius:
  • 1,030 Answers
10 blinks is an indication of hv error. things such as tubes, hv ditribution block. also faulty comotents on d board.
Posted on Oct 13, 2010
It some times happends and some times not.when i push the power button the power buttons get a flash and inside the smps there is also a flash in the same time.but my pc is not started but only my mouse is...
Try this if it's a laptop:
  • Ensure nothing is plugged into the computer
  • Remove the battery
  • Press power button 10 times
  • Press power button down for 30 seconds
  • Press power button twice
  • Attach ac adapter
  • Press power button once. PC should come up. Perform normal start up. Everything should be fine.
  • Shut down and reinstall the battery
Sep 28, 2013 | Lenovo Computers & Internet
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
Dead, power light flashes 10 times then nothing for 4 seconds then flashes 10 times then repeat. This is after I inserted an SD stick.
Unplug,replug the tv about hour later.Tv will,reset itself,back to factory setting.Should have power now.Still have the same problems.The power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My inspirion mini went into hibernate mode, and now won't restart. tried power button, light flashes 3 times but won't come on. tried pulling battery, no luck. Help?
Try this: Disconnect AC power, pull the battery, then press and hold the power button for 10 seconds. Release the button, replace the battery & AC, and try booting.
Mar 09, 2010 | Dell Inspirion Mini 10 Netbook
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
