Question about Samsung DV328AE Electric Dryer
I could not find the ohm readings for the thermistor for a DV293 samsung dryer. Anybody know what they shoud be at room temp?
  • Samsung Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Look inside the back of the dryer. Most Samsung dryers have a tech sheet in a clear envelope usually in the back of the dryer. The thermistor values are on the tech sheet.
I am pretty sure this is the number for it but.... not 100% PN: DC32-00007a.
Thanks for choosing FixYa,
Kelly
Posted on Oct 13, 2010
I have Samsung side by sie refrigarator how do you check the temperature sensor.and the price
Without a model number only a generic answer is possible. Most units use thermistors for monitoring temps. The can be checked at room temperature and should read approx. 1100-1200 ohms (72-75 degrees F). They rarely fail, but are not expensive (~$15-$25).
Oct 31, 2016 | Samsung Refrigerators
What is freezer evaporator thermistor reading at room temp
is it p[ositive coefficient or negative co efficient? usually around 1300 ohms for pce give or take 150 ohms
defrost terminator thermistordefrostterminator-vkiemehpceedlb3juqb40fef-4-2_0.jpg
Oct 15, 2015 | Samsung Refrigerators
What is Code p2 on a Kenmore electric dryer?
error code indicates that the electronic control board detects an open thermistor (temperature sensor). This is usually caused by a failed thermistor. It can also be caused by a wiring problem or a failed control board.
To troubleshoot this problem, follow these steps:
Unplug the dryer to completely disconnect electrical power. Shut off the gas supply.
Remove the bottom front service panel as shown in the first image below.
Locate the thermistor on the blower housing. The second image below shows the thermistor. It should have a red/white and a black wire attached to it. Pull at least one wire off and measure the resistance across the leads of the thermistor using a volt/ohm meter. You should measure about 10K ohms (10,000 ohms) of resistance at room temperature. If you measure infinite resistance or get much different reading, then the thermistor will need to be replaced. Even if the thermistor reads the correct resistance at room temperature, it could still be defective and giving a bad resistance reading at higher temperatures.
If you suspect that the thermistor is good, check the wiring connection at the main control board (black and red/black wires on the P2 connector). The procedure for accessing the control board is shown in the third image below. With the dryer still unplugged, pull the P2 connector (see diagram of board) and check the resistance through the black and red/white wires. NOTE: The wires down below at the thermistor must be properly attached back onto the thermistor to properly check this circuit. If you get a much higher resistance (or infinite resitance indicating an open circuit) when measuring this circuit from the wires at the control board, then you could have a wiring failure that is causing your problem. If the resistance is the same, I recommend replacing the thermistor and testing the dryer to see if it operates properly.
If you still get the error code after changing the thermistor, then the control board will need to be replaced.
Mar 22, 2015 | Kenmore Dryers
Samsung dishwasher dmr57lfs goes quite a long way through the cycle, then throws up error code HE. If I switch off and restart, it goes into "rinse" and then "end" skipping the "dry" cycle can anybod
HE means that there is a problem with the heater. Check the heater for continuity. If it is open, replace it. If it's not open, then, I seem to recall that there is a thermistor or something in there. Check the thermistor for proper resistance (sorry, I can't remember what the reading should be at room temp. But, it most of them are around 5K or 10K ohms at room temp.). If they are both okay, then your control board is most likely malfunctioning and you'll need to replace it.
Good luck.
Oct 22, 2014 | Dishwashers
Error f22
Open exhaust thermistor at room temp should read 11.5-13.5 k-ohms
Jan 22, 2014 | Whirlpool WED6200S Electric Dryer
F01 code on a whirlpool dryer
F-1 code is a open thermistor on most modern dryers. These new fangled machines use electronics to monitor the heat. Instead of the old tried and true klixon with a bi-metal, they now use a fancy gizmo that changes in resistance with temp change. This resistance is monitored by the computer board. They call this part a Thermistor. The thermistor should read 12k ohms @ room temp or thereabouts.
Thermistor replacement is easy enough. Repair Clinic offers a video which shows exactly how to do it. THERMISTOR REPLACEMENT
-Paw Paw
Mar 27, 2013 | Whirlpool duet Washing Machines
I have a ge model dcvh680gj2ww i turn it on and and works for a cuaple of sec and shuts off
Check the thermistor on the blower housing. The thermistor should have a resistance reading. At room temperature it should read around 10,000 Ohms. You can test this with a multi-meter. This usually cause the problem you have described. Here is the part to order in case you find it bad. Post back your results.
Nov 10, 2012 | Samsung DV218AEW Electric Dryer
F25 error code
Having an error code on your appliance can be an inconvenience and I know how important it is to have a good working dryer.
The "F25" indicates the INLET THERMISTOR is shorted or the INLET THERMISTOR circuit is shorted. If you replaced the inlet thermistor and control board then it may have bad inlet thermistor circuit. You should disconnect the thermistor circuit connections at the thermistor and control board and test the thermistor circuit for continuity. Check the circuit to see it happens to be open or shorted with an ohm meter.
The inlet thermistor is located on the side of the heating element housing is a thermistor and high limit combination. The part number is 8557403. The inlet thermistor portion of the thermistor/high limit will have two solid red wires connected to it. It could have faulty new thermistor or it could have an open or shorted thermistor circuit or a faulty control board. The thermistor can be checked with and ohm meter. Disconnect the two red wires and place the ohm meter leads across the two terminals. At room temperature it should measure approximately 50k ohms of resistance. If it measures 50 k, then it should be reconnected and then the sensor circuit disconnected from the control board and retested at the harness wires to see if you get the same measurement reading. If it does measure the same, and it continues to display F25, it could have a faulty control board.
What is your model number?
Oct 16, 2012 | Kenmore Dryers
Kenmore 417-94052500 What should the reading be for gas dryer thermistor. I am testing mine, and it shows 50.0 on my multimeter
Thats kind low actually at room temp it should be appx. 5800 ohms
at 100 degrees it should be 5400 ohms
at 155 degrees it should be 2100ohms
so i would say its bad
GENE
Aug 28, 2011 | Dryers
Model 110 73932101 kenmore elite. Blew the circuit board replaced it and checked the relays. Wont heat, found the thermal fuse is blown. Checked the high limit thermostat and the thermistor. Thermistor...
there is thermal fuse, Hi limit, and thermistor. the thermistor should have continuity at room temp I don't know what resistence(ohms) it should have. Most units I have seen provide a schematic and trouble shooting guide taped under the control panel for service personal.
Apr 15, 2011 | Kenmore Dryers
Samsung DV328AE Electric Dryer Logo
292 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
