Question about Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
I have just fited an IR type 30 compressor to my old receiver, the motor is not up to the job, what size will I need to run it?
  • 7,733 Answers
Trt this link IngSoll.
Posted on Oct 13, 2010
Mix oil and water on motor
Ok, sounds like you are having water vapor condense in your crankcase, must be pretty humid where you are.
1- Make sure the crankcase has a vent on it somewhere.
2- Be sure you are running the compressor long enough to get the oil hot enough to evaporate any water that does get in there. If the compressor is over sized and just runs a few times a day it may not run long enough to flash off the water that does collect.
3- That unit looks pretty big if you sized it to spray paint with it may be way too big for your normal shop use (see 2 above).
Nov 08, 2013 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Sometimes IR 30 goes into a strained free wheeling state
Did you change the 3 phase motor out with a single phase motor? A 3 phase motor cannot be made to run on single phase.
Feb 02, 2013 | Ingersoll Rand - Rand Type - 30...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Hi, I have an old IR Type 30, two-stage compressor, model #: V242 N3. The current motor is 3hp, 1 ph,1740 rpm and may need to be replaced. Is it safe to use a full-speed, i.e., 3450 rpm motor on this...
no you need to use a compressor duty motor same rpm using a higher rpm motor will shorten the life of the motor if you have 3 phase power even better single phase motors aren't as efficient and run much hotter and dont last very long on air compressors
Aug 22, 2010 | Ingersoll Rand Type 30 Electric Driven Two...
Motor pulley for an old Ingersoll Rand type 30 compressor
Here is a link to Ingersoll-Rand (compressed air division) where you can find a local distributor. I think a call to a parts tech might provide the original motor sheave outside diameter and belt size (I'm suspecting "A" or "B" size).
http://www.ingersollrandproducts.com/contact/air/index.aspx
With that info, here is a link to a good industrial source for your new motor sheave (McMaster-Carr):
http://www.mcmaster.com/#v-belt-sheaves/=3fwz7b
Their prices aren't so bad.
You may also have a local industrial sales in your area.
I hope this helps you... Nice compressor!
Sep 01, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5 Logo
69 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
