Question about Echo Garden
On these small 2 cycle motors-the carb has 2 screws. which is high and which is low?
  • 183 Answers
The screw closest to the cylinder is the Lo side and the screw closest to the air filter is the Hi side. From the factory they were set at approx 1 1/4 turn out. They plastic locks on the screws are just pressed on and should be easily removed. The Lo side effects idle and engine rev up. The Hi side only effects engine at wide open throttle. If you have to open up more than 2.5 turns each, then you have a blockage in the carb and it will need to be rebuilt or replaced.
Good luck.
Posted on Oct 13, 2010
Fixed carb still wont run right
If you are sure the carb is rebuilt correctly then you will need to adjust the high speed screw to get the fuel mix right. There is a small H on the side of the carb that denotes the high speed screw and usually takes a special tool to adjust it. The government made them tamper proof but you can purchase splined screw driver to adjust them with.
May 23, 2014 | Craftsman 2 Cycle 30cc Backpack Blower
Where is the fuel mixture screw on poulan pp133
On the carb. Low for initial and high for top end. Start with both at 2 1/2 turns out. Then adjust low when you pull the trigger to eliminate hesitation. Then floor it and hold while you adjust the high
Feb 16, 2013 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Poulan (18"
IN SOME MODELS THERE IS 2 SCREWS NEAR THE CARB.THE SMALL ONE IS FOR LOW REVS AND THE BIGGER IS FOR HIGH.START THE MACHINE AND PLAY AROUND WITH THE SMALL ONE UNTIL YOU GET THE RIGHT LOW REVS,LEAVE THE HIGH AS IT.
I ALSO SUGGEST TO DO A TUNE UP.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I would like to get the proper settings for my low and high fuel jet screws on my 371k chain saw motor
theres no exact setting to use. and they are high and low air screws. the small flat head screw by the throttle lever on the carb is for fuel. but the best way to figure it out is to turn both air screws all the way in and the back out 2 and 1/2 turns. that a good starting point. from there adjust the low with the saw ideling till it sound good and the adjust the high with the throttle wide open till it sounds good.
Jul 08, 2011 | Husqvarna SM 125 Motorcycles
I would like to know what the factory high and low settings are on carb mantis 2 cycle there are no plastic caps on my jet screws and need to know how many turns out ...
After seating the screws back them out 1 1/2 turns. This should be close enough to get it started. Let the motor warm up a little then, with it idling, turn the low screw in until it starts having a hard time running then back it out until it idles smoothly. Prop up the Mantis so it can run at full speed safely while you adjust the high side. With the throttle wide open, again turn the high screw in until it starts running roughly and back it out until the motor is running smooth. Some say to turn the screws out until the motor starts having a hard time running and then turn it back in half way to where it was running bad at the other end. This doesn't work as some engines don't care how far open the screws are.
May 26, 2011 | Mantis 2-Cycle Tiller
Starts and idles just fine, but when you depress the throttle lever to spin the tines it dies
The high-speed carb jet may be fouled. Most 2-cycle carburetors have two adjustable jets, one for idle, another for higher speeds and loads.
May 01, 2011 | Mantis 2-Cycle Tiller
Troybilt chainsaw 20'' bar. will only run until primer fuel is burnt. Replaced gas filter, and soaked carb,and installed a carb.kit.Can`t find any vaccum leads, flywheel and key ok .Help thanks
The idle screw may be turned all the way in on the carb adjuster which should be a very small screw in a 3/16 hole through the plastic cover on the side between the starter rope and the trigger on most saws. Bottom it out and then turn it back 1 and 1/2 turns. Have the saw on a low bench, so you can control it when she starts up - if the revs are too high the chain will spin up which can be dangerous. Now screw the idle down until the chain stops and the motor starts to stall, screw it out a little to get a running idle which will not stall but never starts the chain spinning up. Some have two screws, one for air during idle, the other for the gas during idle. They both should be out about one and a half turns which is industry standard and then you can fine tune from there, but usually only a half turn cw or ccw would be way too much difference from the standard positions.
Apr 10, 2011 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Apr 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
CLEAND CARB NEED TO KNOW HOW TO ADJUST CARB
Most carbs have the adjustment removed (EPA) but if yours still has the adjusting screws here are the seat of the pants methods:
One Screw Carb: Turn it all the way in and then back out 3-1/2 turns, start the engine and make slight turns in or out until the motor runs smooth from idle to wide open, do not get it too lean, turn in until max RPM is reached then turn out 1/8 turn and go from there.
Two Screw Carb: You adjust the one to remedy either the low or high, high is adjusted until the motor runs smoothly under load at high RPM and the low is adjusted until idle and off idle is smooth.
Feb 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Open Questions:
Garden Logo
238 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
