Question about Acoustic Research AR1 Speaker
AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
No power going to one subwoofer on my AR1 Speaker. Took off Sunfire amp off back. Found three fuses. Bottom small 5 Amp 250V blown. Replaced it and it blew immediately upon turning on power. Tried again. Same result. Any ideas? Thanks.
  • stanranger1 Aug 25, 2008
    These subwoofer amplifiers were built by Recoton using Bob Carver's Sunfire technology. When Audiovox bought Acoustic Research, support for the AR1 and other HiRes speakers ceased. I have the same problem but haven't found anyone who can repair these amps. I'm hoping someone on Fixya can offer a solution. Mine spent the better part on two years in a repair shop before he gave up. His guess is a manufacturing flaw, but I have no evidence to back that up.
  • Anonymous Feb 07, 2009
    I sent it to AB Techservices 3 times.
    They fiixing it but problem is stil there. I do not think they trying to
    analise the problem, they just replacing some parts and that's it.
    I thihk Carver sucks.
  • 3 Answers
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
  • 3 Answers
I had the exac same issue. It started out with buzzing sound, but then quickly evolved into blowing the main 250V 5 Amp fuses immediately. I sent mine to ABTechservices.com and they found some blown resistors and leaking capacitors. I'm waiting to get it back (shipping to me now), but supposedly they have replaced and tested and all is working well. I'll let you know how it turns out.
The price they charged me, including return shipping was $187.50
Posted on Nov 11, 2008
Jbl subwoofer fuse
there is a short in the amp that would need to be fixed before the unit will power on
Dec 12, 2013 | Audio Players & Recorders
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
No power geting to my subwoofer from my head unit,also no bass gain on my amplifier !!
There are a few things going wrong here possibly. Its hard to tell without being able to physically troubleshoot, but here's my guess: blown/no fuse. If your amp's power wire is of top quality, you should have a fuse about 4 or 5 inches up from the battery terminal. If this fuse is blown, no juice will flow through to the amp. If this fuse keeps blowing you have a problem and need to get it fixed professionally or you could risk setting something on fire.
Otherwise, check the amp itself for blown fuses, loose power, ground, or remote wires. Last but not least, be sure that you have set your subwoofer output in your headunit setting menu to ON! =]
Feb 22, 2010 | Car Audio & Video
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
The fuse keeps blowing as soon as i power up jbl pb 12
You have an overload in the power supply or main amp of the subwoofer, often caused by short circuited transistor. Check this out by putting an ohm meter probe to each of it's legs. If it acts like you were touching the probes together you have found a guilty part.
Jan 10, 2010 | JBL PB12 Subwoofer
T2.5amp fuse keeps blowing
the fuse keeps blowing because the amp or power supply is blown up. It needs to go in for service. Pro Line Music 215-736-8055
Dec 11, 2009 | Mordaunt Short 309W Subwoofer
I think my subwoofers broken
the coils in the speaker are more than likely shot
Jun 17, 2009 | Sony XS-L121P5 Car Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
AR3 sunfire problems
Try http://www.simplyspeakers.com. Good Luck
May 09, 2006 | Acoustic Research AR3 Speaker
Acoustic Research AR1 Speaker Logo
914 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
