Question about Polaroid FLM-3201 Television
I have a 32" flat panel. Am only receiving one local TV station channel at this time. All other channels show "No Signal". We hooked another TV to the cable and it works fine. What could the problem be? Is the TV worth repairing?
  • Polaroid Master
  • 8,457 Answers
The tv is good,just some LCD tvs some models require a very strong broadcasting signal to get a picture.U getting a free DTV air broadcasting signal wright?Tries getting a roof antena or a digital design antena.Tries this tv out again,will get all the DTV free air broadcasting signal.Should not get anymore "No Signal" result.
Posted on Oct 13, 2010
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
SAMSUNG UE32B6000 have problem with conecting ,it say weak signal,or no signal just blank screen, where do i start,
If you just have over-the-air signals from local broadcast stations, you need a good VHF/UHF antenna connected to the RF input jack on the TV in order to get reception. If you have access to cable TV or satellite, you need to connect the box or receiver set-top-box to the TV using a HDMI cable. You need to select on the TV using the remote, (press the MENU button) setup for tuning channels. Do a scan after setting to AIR or CABLE so the TV picks up all available channels you can get. Once this is done you can change channels and see TV. If you reply back with specifics, I can help more...
Mar 29, 2011 | Samsung UE32B6000 32" HDTV-Ready OLED TV
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Setup 32 inch sansui for digital reception
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
Feb 23, 2009 | Sansui HDLCD3210 32 in. LCD TV
No Signal
I have a 32 in. Haier also, i believe channel 3 should do the job but not sure cause i got mine hooked up threw the comcast digital box and hook it up to my tv threw the video inputs. I was told you get better picuter doing this thats why i got mine hooked up this way.
Dec 13, 2008 | Haier HL32R 32 in. LCD TV
Olevia 32"lcd
All I did was switch out televisions and found that the DirecTV receiver was the problem.
Sep 13, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Audio vs Video
Happens mostly on your local channels right? This is a issue with the local broadcaster and not directv. Due to the digital transition this has been a widespread issue. Until the local affiliate for NBC, ABC, etc. fully transmit a digital signal then this sync problem is to be expected.
Mar 17, 2007 | Insignia IS-LCDTV32 32 in. Television
Polaroid FLM-3201 Television Logo
132 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
