Question about Maytag MSD2756G Side by Side Refrigerator
I have a water leak inside the freezer, it's coming from the openning in the back wall inside the freezer, right on top of the bottom drawer. The water is leaking inside and outside the refrigerator. Can I fix this by myself?
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Our Maytag MTB1976HRW leaks water under the crisper drawer. The drain has stopped up before but if this is the problem how do we solve this without having to call a repair person?
Open the freezer compartment...
Locate screws on the back wall (from inside freezer compartment)
unscrew and open the back panel.
You will see a hole at the bottom which is the drain hole.
if you feel ice there... then that's the reason... the clog wont let water drain out and it accumulates at the bottom after a few days it leaks out of the fridge.
I used a hair dryer to unclog that hole and within minutes I could see water on the drying pan located below the fridge (which previously was dry)
Hope this helpout......
Jul 28, 2010 | Maytag MTB1976HR Top Freezer Refrigerator
Water is leaking into shelf and bottom drawer
its in the freezer part open the back wall of your freezer and you see the hole that the ice should melt into.. if its clog then clean it with water pump....
Dec 30, 2009 | Refrigerators
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 28, 2009 | Refrigerators
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag MSD2756G Side by Side Refrigerator Logo
175 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
