Question about Samsung SCX 4521F All-In-One Laser Printer
Fax Unable to install or connect fax machine. Brought printer used. Did not have a manual.
  • Aaron Falzon May 11, 2010
    do you have the fax cabled connected to the 'line' on the fax?
    if so what is the problem you are having?
    Problem Solver:
  • 10 Answers
There are two sockets on the machine for telphone cable connection. one is for tyhe machine to be connected to exchange and other is for a phone set to mbe connected to machine. connect the line from exchange to the plug marked with "LINE". also check if your telephone company atually support fax communication. some comanies do not support sending of fax on there network. There is no software to be installed for fax. Good Luck,
Posted on Jun 07, 2008
I am using Samsung SCX-4521F machine in which I am able to receive fax messages but unable to send fax using this machine. what should I do to get the problem resolved and to use the machine for both...
Please to assure that the cable from your wall connection go into the printer first and then from there with another cable to your phone. Second set up the printer as fax by using the original soft ware cd or download the programm from samsung webside. Make sure the phone and the fax are compatibile!
Apr 18, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Hp photosmart c7180 unable to send or recieve fax
Issue with Pre- initial ... Check Menu Setup... Check your USB Cable make shure it connect it on both side PC and Fax machine Or Re-install your driver and software for your Printer fax machine
Sep 30, 2010 | Computers & Internet
I can't print anything when connected to my computer
go to and download the drivers there!Run the installation and then connect the fax to the computer!Good Luck!
Apr 24, 2010 | Canon FAXPHONE L80 Laser
Help I have a Lexmark all in one x7675 which I have been using without problems wirelessly. I am trying to use my home phone number as a fax connected to the printer. It seems to work if I ring it from my...
When you ring it from your biz line, does it pick up? If you're using a high speed dsl line, you'll need to put the machine where a normal phone would go. You should be able to ring the machine using our cell phone. If the machine indicates an incoming call, but still doesn't pick up, check the settings and make sure it isn't set to manual instead of automatic fax pickup.
Apr 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
I am trying to use the fax facility on my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Unable to send faxes with HP Officejet 7310xi All-in-One
Fax machines are analog devices and will not work reliably on a digital phone system.
Mar 15, 2009 | Office Equipment & Supplies
Printer busy
sounds like the faxes are stuck in memory
look in the Troubleshooting section of the manual
Jul 17, 2008 | Brother IntelliFAX 4100 Laser Fax
Cannot receive a fax
I had the same problem when i first install my fax machine and at that time I only had the black ink cartridge in the fax machine one's I installed the color ink cartridge, my fax machine started working.
Mar 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message
I can't find the "50" as part of the "Unable to print" error. Usually when you get "Unable to print", it means there's a torn piece of paper, paperclip, some foreign object in the machine somewhere. Check under the scanner lid and inside the machine, look thoroughly; you may find a piece of paper blocking a sensor. If the error message continues, follow these steps before disconnecting the MFC so you won't lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in memory: 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1. Let me know if it helps!
Oct 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
126 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
