Question about Garden
Would like a copy of operating manual for porter cable 5116 omni jig emailed to me
  • 7,733 Answers
Try some diagrams here ->link.
Posted on Oct 13, 2010
Are the 7 degree dovetail bits, that come with the jig, the only size that can be used or can a 9 degree bit be used?
Hi, W/D at your service.
Apparently, there are several types of bits compatible with your model.
Here's a link that gives you a better idea:
http://www.toolup.com/porter-cable_4216_12-deluxe-dovetail-jig-combination-kit.aspx
Best regards, --W/D--
Feb 23, 2011 | Porter Cable Porter-Cable 4216 12" Deluxe...
Need an operating manual, I'd like to know how to use the settings and I want to cut metal
Goto this webpage:
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=9543&selectedType=11514
Click on the small icon to the right of instruction manual to download the PDF format document of the instruction manual
Feb 01, 2011 | Porter Cable 9543 Quik Change Jigsaw Kit
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
I need operating instructions
Here is a direct link to your owners manual. You can print it if you want a hard copy or you can order one from porter cable.
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65507&typeId=14816&documentId=30657
Hope this helps.
Richard
Mar 09, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Dovetail leave a 'light gap'
This may not be related to your jig. It may be movement in the vertical axis resulting from:
  1. The router bearings being worn allowing the bit to move up and down.
  2. The router bearings worn allowing the spindle to deflect side to side which changes the bit height slightly (cuts on the edges, making the cut a hair deeper).
  3. The router collet or router spindle worn, allowing the bit to move during cuts.
  4. The jig guide plate deflecting or no longer flat.
  5. Excess vibration in the router causing the wood to move in the jig.
To check the bearings; try routing the cut with a straight bit first to clear the wood for the dovetail bit. Then cut with the dovetail bit (a new one preferably) using very light feed pressure. Is the joint tighter? If so then the bearings are worn. Have the router serviced or replace it.
Check the end-play by pulling on the router shaft, does it wiggle slightly in and out? If so this is your problem. Have the router serviced or replace it.
Be sure the wood is flat and the faces planed parallel, if they aren't the dovetail line will be straight but when you assemble there will be slight end gaps in sections of the dovetail.
Feb 23, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Need a manual for PC omni jig- original model
You will need your model #
Here is where to get your manual
Good luck and let me know if I helped
Jan 06, 2009 | Porter Cable 55160 16 Inch Omnijig...
Jig Saws Adjustable foot
An adjustable foot is the metal plate at the bottom of the saw which will pivot between 0 and 45 degrees. This will allow you to make angle cuts in the wood
Aug 27, 2008 | Porter Cable Cable 53530 Edge Guide for...
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
