Question about Timex Watches
I had the battery replaced on my Timex, Compass watch today And now I cant set it Bill
  • william_ivil Oct 14, 2010
    When I press the lower right button, I get the message NO OCCN.
    And I can go no further.
    Thanx,
    Bill
  • william_ivil Oct 16, 2010
    NO OCCN, when lower right button is pressed, after battery changed, on TIMEX WR100M Compass watch. Unable to set, anything.
    Bill Ivill
  • 3,083 Answers
The button switches could have some dust or oxidation, and need cleaning. I would suggest taking it in to a jeweler and have them clean the button switches and ensure the battery contacts are clean, also.
You can do this yourself if you have the expertise, but otherwise I would recommend taking the watch into a reputable jeweler.
Good luck, and hope this helps.
Posted on Oct 16, 2010
  • 2,382 Answers
Hi, this is how to set time on your Timex Watch
Analog (Dial) Watch
  • Locate the knob on the side.
  • Pull the knob out. The second hand should stop ticking.
  • Twist the knob clockwise until the correct time is displayed on the watch face.
  • Push the knob back in, and the the second hand will resume ticking.
Timex Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
  • Press the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance"button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Posted on Oct 13, 2010
  • Tunde Autos
    Tunde Autos Oct 14, 2010
    Hi, that is a very strange message that i have never heard of on the Timex watch. I think you need to see a watch repairer to check that out...
The compass on myTimex WS4 fails to calibrate. Have tried removing the battery and resetting everything but still no joy. Is the any other way to calculate the compass?
There is a process to make an all reset. After the reset try again. The user user manual can be downloaded from Timex. Make very sure the watch is absolutely flat and far from metal objects. Even being near most furniture can effect the reading because they can have metal springs. Many homes have a lot of metal in their construction. It's best to calibrate the compass out doors away from power wires or cars or anything metal. On the street you can have metal under the pavement.
If this does not work call Timex. There have been instances where the compass module or sensor had to be changed. I have the same watch. It's a very good one.
Sep 25, 2014 | Timex Expedition WS4 WideScreen 4...
My time e-tide compass sohws large deviations (>90 degrees) after calibration. I've tried calibration several times, each resulting in slightly different north. The degree of variation per heading...
Low battery can cause this type of fault! Make sure after changing the battery to do the all reset inside of the watch. If this does not work get in contact with Timex for how to have their watch sent for service.
Jan 17, 2018 | Timex Expedition E Tide Temp Compass...
Timex compass properly not working
First, assuming you do not have the manual, following the notes below, find an outdoors location away from any medal building, obstructions, etc. You must calibrate the compass to get anywhere near the +/- 10 degrees accuracy readings claimed.
Timex has two ways to find information about your particular watch. If you don't have the manual, Try this link:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 08, 2010 | Watches
Can i find instuctions to compass watch
Sep 07, 2010 | Timex Expedition E Compass Watch Titanium...
I own a new timex expedition and cant figure out how to set the alarm, can you exoplain how?
Complete Timex link site:
Sep 05, 2010 | Timex Expedition 84601 Wristwatch
I though I had a dead battery and had it replace since then it looses time and the compass does not work Does this watch have two batteries The person that replaced the battery could not see but one...
The Timex web site for similar models implies only one battery.
I would have thought space was a little too restricted for two batteries.
It seems likely that there is something else wrong and the watch should therefore be taken to an authorised repair agent (see Timex web site for details).
Mar 17, 2010 | Timex Expedition 40141 Wristwatch
I have a Timex e-tide with compass, temp and tide functions. The compass no longer points north and will randomly point in any direct when activated, is there a way to re-calibrate the compass?
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Expedition Adventure Tech Compass...
Timex Expedition E-Instruments E-Compass Watch
Timex makes its manuals available for download from their website:)
http://www.timex.com/gp/node/n/255235011/178-9815641-8595102?ie=UTF8&timexBrand=core
Sep 21, 2009 | Timex Watches
I'm looking for a watch strap for a ladie's Timex expedition Adventure Tech watch. Where do I find one??
Timex stores are the only place I have been able to find their straps consistently. If you have a standard lug set up you might be able to get a similar after market strap at your local repair shop.
For Timex locations visit their web site...
Timex.Com
Sep 12, 2009 | Timex Expedition Adventure Tech Compass...
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Watches Logo
746 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
