Question about ASUS P5GDC Deluxe Motherboard
Hello windows 7 won't install due to it asking me to load a driver. i do not know what this driver is? it makes no sense!
Cant install Windows 7
Makes no sense. All operating systems during install have generic drivers designed to work the installing drive. If you are getting this message it has to be bogus and I suggest trying another dvd drive in its place.
Mar 29, 2014 | Computers & Internet
Lenovo k430 won't boot windows 7
might due to harddisk partition and format.
you need to use other utility software to format then only install.
But your recovery parttition will gone.
Never able to restore back to win8
Mar 02, 2013 | Lenovo K430 31092JU Desktop PC Windows 7...
Hello, I am trying to install my d-link 125 usb adapter. I had to download the windows 7 driver from the d-link website, and now I am trying to install it to my computer. When I try to run the driver...
Use the following steps to let Windows do the installation for you.
Step 1: Use an Ethernet cable and plug your computer directly to your Internet gateway. Make sure Internet is accessible.
Step 2: Place your new adapter in the proper slot or port.
Step 3: With your computer running, a bubble message will appear stating that this device was not installed successfully. Left click on the message.
But if the message no longer appears, skip to Device Manager Installation.
Step 4: On driver installation failure, you can change the setting to use Windows Update by clicking Change setting...
Step 5: Chose to allow Windows to update your driver when it is not found on you computer.
Step 6: Once the driver installs successfully, close the window.
Step 7: Click/Right Click on the Network Icon located on the system tray to View the Available Wireless Networks. Find your personal Network and double click to connect. It should request for a wireless key, which by now should have been set up.
Oct 26, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
I hv mindows 7 installed n so no sound coming
try to find the sound drivers for your sound card. Make sure the drivers are for Windows 7
Jul 12, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When I try to install Windows 7 onto a new primary HDD, the procedure asks me to first load some drivers for the motherboard. But Windows doesn't tell me how to do it. What do I do? I've never seen this...
You need to have the disc for the drivers. When the system askes you to load them, it will have a drivers button to do this.
There is an easier way to do this if you have another computer available. Look at this guide
Using that method you can take all your drivers for your motherboard, slip them into the windows 7 dvd and then make a new copy to install from. This will circumvent the need for it to ask for the drivers.
Mar 02, 2011 | Gigabyte GA-VM900M Motherboard
Tryen to load windows 7 on a formatted hard drive on my tough book when i get to the installing windows screen it askes me for drivers what kind of drivers is it looking for
Hello
Win 7 is asking if you have the sound drivers or video drivers or ethernet drivers.
To explain different,Win 7 is asking if you have a utility disc that came with your notebook.
I would choose the let windows find the drivers option and continue the install.
Feb 06, 2011 | Panasonic Toughbook CF-30 Notebook
When i click to open '3connect manager' it loads for a few seconds but nothing happens, the program won't open. i am on windows 7. why won' it open?
HELLO TRY UNISTALLING THE DONGLE ,THEN TURN OF UR USER ACCOUNT SETTING,AND UR ANTIVIRUS ,REINSTALL UR DONGLE MAKE SURE U GIVE IT TIME TO INSTALL ALL THE DRIVERS FIRST BEFOR U DO ANYTHING IT WILL TAKE A WHILE ,THEN TURN USER ACC ON AND UR ANTI RESTART THEN PRESTO,IT INSTALLS THEN STARTS TO INSTALL THE OTHER DRIVERS AFTER JUST LOOK AT BOTTOM ON TASK BAR ,TO UR RIGHT ,HOPE THIS HELPS
Jan 10, 2011 | Computers & Internet
My Acer Webcam Is Gone Ever Since I Installed Windows 7!?
As with all laptops parts are sourced from different manufacturers. Laptops had to be certified for WIN 7. Some ACERs laptop models are, but if the model wasnt certified for the WIN 7 platform they would not have developed a driver for your model. After checking ACER did NOT certify this unit as Windows 7 Compatibile due to driver incompatibilities. You can either downgrade to Windows Vista.. which will require a full reformat of drive (WIN 7 doesnt just uninstall) and reinstall from fresh VISTA.. so be sure and save your data. Or you can determine who makes the webcam in teh notebook and see if the manufacturer has a direct driver..OR FINALLY.. you could load the Vista driver and then go into the webcam software you use and right click and say run in "Windows vista" or "Windows XP" compatible mode. Be sure and keep looking at ACER to see if they state your system can go to Win 7 at a later date as sometime manufacturers will make drivers available which could change its status.
Jun 02, 2010 | Acer Aspire 5610-4648 Notebook
Have netcore310g adapter got cd. computer crashed had to reload everything now my wire won,t work, IT LOOKS LIKE DRIVERS WON,T LOAD -HELP. TRIED TO LOAD MANUALLY NO LUCK PLEASE ADVISE WHAT TO DO TRYING...
You will want to check in your device manager to see if the network card is not being recognized and you will be able to update the driver there.
For windows XP, rght click on my computer, select properties and then select "ahrdware" and device manager.
For windows VIsta and 7, go to your control panel and open Device manager there.
Once open, you should see a network adapter with a yellow question mark or yellow exclamation mark beside it.
In either case, make sure the driver disk is in your disk drive, right click on the network adapter and select "update driver"; then just select the "recommended" options and follow through.
If this still doesn't work, try uninstalling the device from the device manager and then install the drivers using the disk.
Thanks,
Pat
Mar 29, 2010 | Computers & Internet
Re-installing drivers on dimension 4550
You don't mentioned the model you ask for, but from my experiance, usually it has to be done in the following order:
1. Chipset/motherboard
2. IDE/SATA (if any)
3. VGA
4. Audio
- Wireless Lan
- Lan
- Modem
- TouchPad
- WebCam
- Special (Quick-launch) Buttons
- Utilities
- Software
of which firs 4 are important, other drivers can't realy cause problems if you mix their order of installation.
Regards.
Mar 27, 2009 | Computers & Internet
ASUS P5GDC Deluxe Motherboard Logo
22 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
